586,096 active members*
3,444 visitors online*
Results 1 to 18 of 18
    Aug 2011
    252
    Pre sale questions
    I want to buy a new controller (I have mk1 DIY) and have some questions. Below is what I understand that I need to make the change:
    controller https://planet-cnc.com/product/cnc-u...er-mk3-9-axis/
    license https://planet-cnc.com/product/cnc-u...oller-license/
    connector kit x 2 for 5 axis https://planet-cnc.com/product/connection-kit/
    Is this enough to migrate from my DIY MK1 to the new one?
    And most important, is this controller capable for 5 axis simultaneous machining?
    Best Regards
    Mar 2017
    1312
    Re: Pre sale questions
    I would just add that you might find these adapters more useful for connection with your existing drivers, switches etc..:
    https://planet-cnc.com/product/limit-input-board/
    https://planet-cnc.com/product/adapt...rew-terminals/
    Yes, you can use 5axis machine with our motion control system.
    Make sure that you will be using suitable 5 axis gcode.
    Aug 2020
    131
    One think to notice with the "Adapter with screw terminals": This does not offer you a direct port for the error pin. This only matters when you use CL stepper or servos and you can get around this, but should be mentioned nevertheless.
    Mar 2017
    1312
    New screw adapters have error pin. This is no longer an issue.
    Aug 2011
    252
    Thank you both for answers.
    I see that limit input board include cables and pin connectors, it is the same for adapter with screw terminals?
    Mar 2017
    1312
    Yes, all adapters have cables to connect to controller included.
    Aug 2020
    131
    Quote Originally Posted by PlanetCNC View Post
    ohh thats great.
    Aug 2011
    252
    So if I order the two adapters that you suggested I don`t need anymore the connection kit, right?
    Aug 2011
    252
    This is to much for me, and I need two of them for 5 axis and 1 slave, so I ask if I order one connection kit can it be only with 10 pin connectors 7 of them with ribbon cable instead of 4x10 pins and 3x16 pins?
    And off course I will get one adapter for limit switch.
    Mar 2017
    1312
    No problem. Just write us a note when you make your order.
    Aug 2011
    252
    Ok, thank you, order placed.
    Aug 2011
    252
    Did you received the emails from me?
    Just ask because I have no responses on my email, only one automated response from Friday when I placed the order.
    Mar 2017
    1312
    Yes, we received your order.
    Because of covid we process orders once a week.
    Aug 2011
    252
    Well, I did not know that COVID spread even through emails and that be the reason for not getting an answer to my email.
    JUST JOKING, sort of...
    Best Regards
    P.S. I also expect an answer to my email (no joke here)
    Mar 2017
    1312
    Sorry. I wrongly assumed your question was order related.
    Aug 2011
    252
    When I asked about "is this controller capable for 5 axis simultaneous machining?" I meant 5 axis interpolation motion (aka blend motion).
    So after I bought the controller and build my 5 axis, I found that controller can not interpolate (or blend) motion between linear axis and rotary axis. You can use it for 5 axis machining, but at any linear axis change direction no mater how small the trajectory change, it will decelerate to stop and start again. That certainly is annoying and also time consuming.
    I wrote this here so that others would not make the same mistake as me. Go find a controller that can interpolate motion on all axis.
    Aug 2011
    252
    Today I browse your shop and found this:
    https://planet-cnc.com/product/extinout/
    There is an info: : "This board can be used with MK3/4 controller V2 version(red connector is present on controller). V1 version is not supported!"
    I checked my controller and is the older version 1.2, I didn't see that when I received the board.
    I'm 100% sure that when I ordered the controller was this picture on the shop witch is version 1.3.
    Attachment 491462
    Now I want to know why I received the old version instead of the one that was advertised on the shop page?
    Mar 2017
    1312
    You bought controller in March 2021, picture was changed on April, 15 2022, more than a year later. Mk3 v1.2 was out of stock long before picture in web shop was changed.
    But v1.2 has Ext connector which can be used with ExtInOut board. Comment about red connector applies only to Mk3/4 controller which did not have Ext connector.
  1. YXH big sale great sale reduce $300-$700 with good quality
    By alvincncrouter in forum News Announcements
    Last Post: 11-19-2018, 03:53 AM
  2. Good quality and cheap Lathes Lathe/Mills for sale NZ. Private sale, limited stock.
    By boydage in forum Australia, New Zealand Club House
    Last Post: 08-19-2014, 08:21 AM
  3. Dynapath System 10 questions (for sale?)
    By ice9er in forum Dynapath
    Last Post: 05-12-2010, 04:59 AM
