586,043 active members*
3,687 visitors online*
    Aug 2005
    'IF' problem on MK1
    I've been freaking out for a while.
    Anyone who knows the CNC USB Controller software (ver 2.10), can explain to me why in this program below, when the condition of the if is not verified, the instructions after the endif are not executed, while if the condition is true they are performed? Being after the endif they should not be conditioned, it is as if all the rest of the program after the endif were considered as an integral part of the code to be executed in the event of a verified condition, that is, as if the endif was not there.
    #1=0 (x CENTRO)
    #2=0 (y CENTRO)
    #3=20 (RAGGIO)
    #4=5 (FINITURA)
    #5=0 (profondita iniziale)
    #6=-10 (profondita finale)
    #7=5(profondita passata)
    #8=#5 (profondita attuale)
    G00 Z5
    G00 X#1 Y#2
    G00 Z#5
    O140 do
    #8=[#8-#7]
    G01 x#1 Y#2 Z#8
    G17 G02 X[#1+#3-#4] Y#2 R[[#3-#4]/2]
    G02 X[#1-#3] Y#2 I[[#4/2]-#3]
    G01 X[#1-#3] Y#2
    G02 X[#1-#3] Y#2 I#3
    O140 while [[#8-#6] GE #7]
    O5 if[#8 NE #6]
    G01 x#1 Y#2 Z#6
    G01 X[#1-#3] Y#2
    O5 endif
    G01 X#1 Y#2
    G00 Z#10
    Aug 2011
    252
    Re: 'IF' problem on MK1
    Because your #6=-10 (profondita finale)
    And you have O140 while [[#8-#6] GE #7] -> that is 5-(-10)
    Try
    O140 while [[#8+#6] GE #7]
    and I guess it should work
    Best Regards
    Aug 2005
    Quote Originally Posted by adidoro View Post
    Try
    Best Regards
    The malfunction is not on cicle Do While. This cicle is done correctly. The problem is after. On block o5 and into istruction after IF condition. The cicle do While work and terminate good.
    Aug 2011
    252
    My mistake, I will look closely to code.
    Aug 2011
    252
    Now that I have the new TNG software I run your code in simulation and worked, so the code is fine.
    In older planet CNC software for mk1 did not work.
  1. Replies: 1
    Last Post: 11-24-2017, 03:56 AM
  2. Fadal Idler problem. Rpm pulse problem
    By complextool in forum Fadal
    Last Post: 10-07-2016, 06:28 PM
  3. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  4. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  5. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
