586,070 active members*
3,430 visitors online*
    24221
    Power isolated?
    Is the I/O on the Larken drives isolated from earth ground?
    Albert E.
    Feb 2007
    966
    Re: Power isolated?
    ... better late than never
    Yes on the Viper 200 series, the control side is opto isolated from the power side . So input signals and encoder are running off the low voltage safe side. The main power and armature connections can be floating .
    On my smaller low voltage drives .. V60 and S2L , its a single power supply with common ground for all
    How are you doing Al , good to see your still at it .
    Larry K
  1. Isolated break-out board
    By yassser in forum Computers / Desktops / Networking
    Last Post: 03-06-2012, 04:43 PM
  2. isolated power for parallel port optocouplers
    By mike944 in forum CNC Machine Related Electronics
    Last Post: 05-30-2007, 11:32 PM
  3. 220/100 Volt non isolated power suplly for step motor drivers
    By bunalmis in forum CNC Machine Related Electronics
    Last Post: 03-30-2007, 04:36 PM
  4. Electricity isolated from power-grid?
    By medved in forum Waterjet General Topics
    Last Post: 03-16-2006, 01:28 PM
  5. I need to isolated the problem.
    By on7tim7 in forum Mach Mill
    Last Post: 12-04-2005, 12:01 AM
