586,076 active members*
3,783 visitors online*
Results 1 to 8 of 8
    Mar 2021
    Help with spindle control Mach 3
    Hoping someone can help with a spindle issue. I have my spindle finally set so it will work in Mach 3, we’ll kind of. It will turn on and off if I uncheck use spindle motor output unchecked and check PWM control. It will work if I have a minimum PWM of 15% but adjusting the speed up or down doesn’t do anything. Additionally on the RPM, S-ov and spindle speeds all show zeros when running. Any help on what I need to look at or adjust is appreciated. Also I have a huanyang 110V 1500W Air Cooled Spindle Motor 1.5KW Square CNC Machine Tool Spindle + 110V 1.5KW Inverter VFD.
    Attached Thumbnails Attached Thumbnails 802CFD4E-76A6-4326-9D65-323A0F7C641D.jpg   70BAF3A1-E179-4C47-8687-A6CA4EB79046.jpeg
    Apr 2004
    5737
    Re: Help with spindle control Mach 3
    What's sending the analog 1-10vDC signal to the VFD that controls the spindle speed? Do you have a PWM to analog converter, or something on your breakout board that sends out a DC signal? There's some discussion of this on the Machsupport forum: https://www.machsupport.com/forum/in...?topic=33375.0
    Andrew Werby
    Website
    Mar 2021
    [QUOTE=awerby;2438190]What's sending the analog 1-10vDC signal to the VFD that controls the spindle speed? Do you have a PWM to analog converter, or something on your breakout board that sends out a DC signal? There's some discussion of this on the Machsupport forum: https://www.machsupport.com/forum/in...?topic=33375.0[/
    I’m not sure but attached wiring diagram provided by company I purchased the controller kit from. Hope this helps clarify.
    Mar 2021
    Jan 2021
    27
    My spindle settings are different from yours. I think my spindle is working correctly, it seems to do everything but display RPM, but that is my cheap motion cards fault.
    - Your spindle page top left corner - spindle relay - mine is checked.
    - then below that, my disable flood/mist relays is checked.
    -- and in the top middle - Motor control use spindle outlet is checked.
    Also I just found Mach 3 check config in the top of screen Operator pull down menu. That may help you pinpoint errors.
    Apr 2005
    304
    To be able to start and stop spindle, spindle relay check box should be unchecked and correct output selected.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    15362
    Quote Originally Posted by Rgam2004 View Post
    What VFD Drive are you using and which Breakout Board The PWM=100 %=0
    Need more information
    Mactec54
    Jan 2021
    27
    Wait sorry -- I was wrong
    "" - Your spindle page top left corner - spindle relay - mine is checked. "" was incorrect .. My spindle relay box is NOT check marked
  1. Mach Spindle Control
    By cncknockout in forum Mach Software (ArtSoft software)
    Last Post: 03-07-2019, 02:01 PM
  2. ESS to C32 spindle control with Mach 3.
    By ballistic42 in forum Benchtop Machines
    Last Post: 08-09-2015, 02:39 AM
  3. SX3 Spindle Control via Mach-3
    By JimsCNCZone in forum X3/SX3/G0619/G0463
    Last Post: 09-05-2012, 11:00 PM
  4. SX3 with Mach 3 Spindle Control.
    By cjdavis618 in forum X3/SX3/G0619/G0463
    Last Post: 02-22-2012, 03:27 AM
  5. Mach 2 / 3 VFD Spindle control
    By JpBinc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2008, 04:46 AM
