586,075 active members*
4,261 visitors online*
Results 1 to 3 of 3
Threaded View
    Dec 2006
    102
    RFQ - done, bid accepted.
    Material - any machinable aluminum.
    Description: 5/8" dia. cylinder x 1/2" length, ends faced off or ground flat. 3/16" wide slot milled 1/4" deep on one end (centered), hole d & t for 1/8" NF thread at right angle to slot* (centered) 1/8" from cylinder end drilled from one outside face to inside of slot.
    See sketch.
    Quantities - about 12 per order after sample approval.
    *and cylinder axis
  1. small part need quote 300 pcs.
    By joey1117 in forum Employment Opportunity
    Last Post: 02-16-2007, 03:08 AM
  2. RFQ - Small CNCed aluminum part, batch of 50
    By Enraged in forum Employment Opportunity
    Last Post: 01-22-2007, 02:26 AM
  3. RFQ - CNC part prototype / small run
    By MrTman in forum Employment Opportunity
    Last Post: 02-27-2006, 10:17 PM
  4. Replies: 2
    Last Post: 04-30-2005, 11:34 AM
  5. RFQ Small part
    By impact in forum Employment Opportunity
    Last Post: 02-14-2005, 09:05 PM
