586,121 active members*
3,139 visitors online*
Results 1 to 12 of 12
    Mar 2007
    23
    repetitive cycle on Fanuc 21 TA
    Recently I want to add repetitive cycle function on my Fanuc 21TA. I changed the option parameter but the bit stayyed '0'. Could anybody tell me why? or is there any special procedure to do this..?
    I need your help guys..
    Jan 2007
    355
    Fanuc controls have a PWE bit (parameter write enable) which must be set to '1' before other parameters can be changed.
    Not sure what location the Fanuc 21 TA uses, but it should be listed in your user manual.
    Make sure that the bit is reset to '0' after the changes have been made.
    49
    PWE screen should be obtained by pressing the offset/settings key on the controller (it may take a couple of time when pressing the offset/settings key) to change this to write enable you must have your mode select switch to MDI from there you can change the parameter you want while you are still in MDI mode when you are done changing the parameter you needed to change don't forget to change the write enable back to write disable still being in the MDI mode selection , hope this helps!
    Jan 2007
    333
    Turn the edit key to enable.
    May 2006
    265
    Hmm,, arent there passwords used on 16,18,21 ?
    Mar 2007
    23
    Thanks guys for your replies.. but I had tried to set it with PWE on, MDI mode on and edit key enabled. May be M-man's right, arent there passwords used on 16,18,21 ?
    Jun 2007
    119
    Alarm?
    Which alarm appers when you try the change the parameter?
    May 2006
    265
    Mabe it will work if you punch all parameters to Pc and change them there and then load them back to machine...
    Jan 2007
    333
    Which parameter are you trying to change?
    Mar 2007
    23
    I changed prmtr 9921#7, then alarm 'POWER MUST BE OFF' appeared. Then I tried to punch the nc parameter to PC, change 9921#7 to 1, and upload back to machine. the bit stayed 0.. and again alarm 'POWER MUST BE OFF' appeared.. any ideas?
    Jan 2007
    355
    Some parameters changes do not take effect until the control is powered down then powered up again.
    Are you sure that the parameter is unchanged when you power up?
    Mar 2007
    23
    The parameter remained unchanged when i powered up..
  1. g76 thread cycle for dummies 20i fanuc
    By avccrml in forum G-Code Programing
    Last Post: 07-24-2018, 02:08 PM
  2. Extracting cycle times from FANUC OT
    By swilly in forum Fanuc
    Last Post: 12-30-2006, 11:19 PM
  3. Extracting cycle times from FANUC OT
    By swilly in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-13-2006, 02:17 PM
  4. Making a Jig for repetitive pieces
    By Burn in forum Benchtop Machines
    Last Post: 06-28-2006, 09:18 PM
  5. fanuc -om peck cycle
    By PETE1968 in forum Fanuc
    Last Post: 04-06-2006, 03:57 AM
