586,058 active members*
3,366 visitors online*
    May 2008
    12
    A2100 CONTROL HELP
    Hi all,
    I have a falcon lathe with an A2100 control that had been working fine
    up till now. The machine sat for a few months and now I get a blank
    screen when I push the start button. - nothing- I remember having this problem with
    other machines we had in the past and it was usually a simple fix.
    Anyone know where to start ?
    thanks
    Jim
    Dec 2006
    584
    Re: A2100 CONTROL HELP
    Look at the power supply in the A2100 control box, is the fan running, do you have 220 vac at the black plug, is the green light on inside the small open window on the left bottom of the control box. Do you have power in the mag panel?
    MIKECNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Mar 2011
    463
    CRT or LCD screen? I have had to replace a lot of backlights over the past few years.
    Be careful throwing the power off without at least trying to shut it down. If it is the backlight, the control is still loading and killing power during the software load can corrupt your hard drive (givimg you 2 things to fix.
    Also possible a dead battery on the WS board. There were a few of the boards that couldnt boot up it the CMOS battery died.
    Oct 2011
    205
    As Mav said, you might run into problems with the hard drive turning on a off. I would disconnect the hard drive to eliminate any chance of corrupting it.
  1. A2100 control repairs
    By supraman in forum Cincinnati CNC
    Last Post: 07-16-2015, 04:42 AM
  2. A2100 control touch screen fix
    By etwheels in forum Cincinnati CNC
    Last Post: 07-08-2014, 08:47 PM
  3. HELP!!! on Siemens A2100 control
    By Greg Kitkowski in forum SIEMENS -> GENERAL
    Last Post: 03-26-2014, 02:48 PM
  4. Tree 250 Jouneyman / A2100 Seimen control
    By tommydee in forum Tree
    Last Post: 09-21-2013, 05:15 PM
  5. saber 500 A2100 Control
    By vebers in forum Cincinnati CNC
    Last Post: 09-27-2011, 07:06 PM
