586,075 active members*
3,871 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18-T Ecoca SJ-20 Parameter 6700 not working. Stops on block/m-code
    Mar 2021
    So my small lathe are used for a lot of automated production but the part counter only counts on M30/M02.
    So i won't count until it receives a M30/M02, which means the program will end.
    I've tried to change the 6710 to a different M-code. But it will accept the code +1 to the counter but won't continue to the next block.
    So it freezes on it.
    Thanks in advance
    Re: Fanuc 18-T Ecoca SJ-20 Parameter 6700 not working. Stops on block/m-code
    What ever M Code you decide to use when setting parameter 6710 HAS to be pre written in the ladder to FIN out. Otherwise you will have to add that to the FIN circuit in the ladder. (G4.3 in the PMC Ladder)
    Mar 2021
    Quote Originally Posted by drdos View Post
    Do you know if it's possible to edit the ladder on this machine or do I need to dump the pmc ladder to be able to edit it
    It all depends on the PMC type that you have. Also the FULL controller type. Fanuc made "5" 18T controls. 18TA, 18TB, 18TC, 18TiA, AND 18TiB which one do you have? If you can post your ladder with the M code you want to use I can see if I can make the change for you.
  1. ECOCA Barfeed integration NC Error without code
    By gollame in forum Uncategorised MetalWorking Machines
    Last Post: 10-12-2015, 11:13 AM
  2. Replies: 0
    Last Post: 03-01-2014, 07:18 PM
  3. Replies: 7
    Last Post: 05-07-2012, 10:24 PM
  4. Replies: 1
    Last Post: 11-19-2010, 03:05 PM
  5. Block look ahead bypasses M1 optional stops
    By Paul_S in forum Haas Mills
    Last Post: 03-08-2005, 06:37 AM
