586,616 active members*
2,446 visitors online*
Hybrid View
    Feb 2007
    1538
    Tormach Rigidity
    Was wondering if any of you do heavy machining - steel etc - and know the machines weakest link. I imagine under heavy cuts flex of the vertical column,base to vertical column or head would allow cutter chatter. Going off my Syil x3 and allowing for the Tormachs heavier proportions I imagine a 1/2 inch HSS end mill cutting say Mild Steel at sensible revs and feed - might be at its limit at say 1/4 inc depths? If there is a weak link that lets the rest of the machine down/has anyone made mods to beef the machine up - or is the machine quite balanced in its proportions? welcome youre thoughts.
    Jun 2006
    2512
    Maybe you have seen this, but just in case.
    http://www.tormach.com/mfg_database.htm
    There are 2 steel milling examples with technical details and videos.
    Phil
    Quote Originally Posted by keen View Post
    Feb 2007
    1538
    Thanks Phil - Yes I've seen that - it seems about as ridgid as my manual Kondia (bridgeport type). Thats pretty useful! The 1/2 inch rippa cutter stage is impressive - not sure why it was faced with a 1/4 inch cutter though? I have just heard my Tormach will be here in NZ end of August - so I will soon know.
  1. Milling rigidity question
    By pminmo in forum MetalWork Discussion
    Last Post: 05-30-2008, 07:29 PM
  2. Tormach
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 05-01-2007, 02:30 PM
  3. Locking Quill & Splines for Rigidity
    By BobWarfield in forum MetalWork Discussion
    Last Post: 08-07-2006, 09:08 PM
  4. Fadal VMC Rigidity for Machining Steel
    By kurbelgehause in forum Fadal
    Last Post: 03-23-2006, 04:28 PM
  5. machine rigidity
    By frankv in forum Mechanical Calculations/Engineering Design
    Last Post: 05-11-2005, 01:30 PM
