586,117 active members*
3,510 visitors online*
Results 1 to 8 of 8
    Sep 2005
    28
    TL-1 noob, need some help.
    Hi all,
    We have a Tl-1, have had it about 6 months and it mainly just gets used for little things here and there. I have to do a small run of parts and am in the process of building a gang tooling holder for it. I think I have this mostly figured out but have a question about work offsets.
    I understand how to set the tool offsets on a one by one basis for a part but I can see how this would be a pain in the butt if you are using different stock lengths with different programs. Do you have to go and reset each tool offset every time you change what part you are making?
    I was hoping that I could set a WORK offset and just change that and be good to go. I understand work offsets on the mill and maybe I am incorrect on how they work on the lathe.
    I looked in the manual, but the lathe manual in my opinion is just about useless, especially when it comes to the tl-1.
    Could someone please walk me through a simple gang tooling with work offsets setup? I think I am missing some part of the big picture.
    Thanks!
    Chad
    Jul 2005
    12177
    Try doing a search or scan through the threads in the Haas forum. This was discussed a while back.
    I use gang tooling frequently on a TL1 and also multiple work offsets so if you can't find the previous posts I can give some suggestions.
    EDIT:
    Found it
    http://www.cnczone.com/forums/showthread.php?t=33866
    Sep 2005
    28
    Hi Geof, Thanks for that link, I read that thread a while ago and have been looking for it. I think I have the tool Tnn stuff figured out, we will see.
    The thing that I don't understand is the work g55 offsets, and how that relates to to the tool offset. I will keep searching..
    Chad
    Jul 2005
    12177
    Quote Originally Posted by chad123 View Post
    ....The thing that I don't understand is the work g55 offsets, and how that relates to to the tool offset. I will keep searching..
    Chad
    The G5n work offsest simply moving everything by whatever is in the offset table.
    The machine uses G54 by default and if you never put any values in the G54 line when you do your tool offsets they are taken from machine zero.
    The X tool offset, X DIA MESUR, is (nearly) always the spindle centerline.
    For the Z tool offset, Z FACE MESUR, some people use the face of the chuck but I prefer to use the end of the stock; actually I normally make it the finished end so my rough stock starts out a bit further than Z zero.
    When there is no value in G54 both the X and Z values in the tool offset table are the distance from machine zero to the centerline for that tool or to the end of the part for that tool.
    When there are values in the G54 work offset then the tool offsets are taken from this position. For instance if you entered tool offsets with noting in G54 then put a negative value in G54 Z you are going to finish up with the tool somewhere inside the chuck.
    I never use anything in the X value for work offsets but often use Z values in G55, 56, etc., but not G54. This is when I am using a length of bar making small parts where I can have enough material out of the chuck to part off two or more pieces.
    To do this I set the machine up and put the Z tool offsets in at the end of the stock. As I mentioned G54 stays at zero but in G55 I enter a Z -value equal to the length of the part plus the parting tool thickness plus a facing allowance; G56 gets twice this, G57 three times, etc.
    The program I make into a subroutine which is called after the selection of work offsets. Something like this;
    O00000
    All the normal stuff
    G54 M97 P1000
    G55 M97 P1000
    etc
    etc
    G54
    M30
    This machines all the parts stepping along the bar and then goes back to G54 and stops.
    To simplify setups I enter the values for G55, 56, etc from the program using a G10 offset entry command. This makes the program;
    O00000
    G10 L2 P1 Z0. (Set G54 to 0.) Not essential
    G10 L2 P2 Z-1.2 (Set G55 to Z-1.2)
    G10 L2 P3 Z-2.4 (Set G56 to Z-2.4)
    etc
    G54 M97 P1000
    G55 M97 P1000
    etc
    etc
    G54
    M30
    There are other ways to do the same thing. Also sometimes there may be reasons why you want to use X values in the work offsets but I think this is enough to go on with.
    Sep 2005
    28
    Ok, That is what I was confused on. Thank you so much! it all is getting clearer now. Now I get the gist of it all and have a place to start..
    Chad
    Jul 2005
    181
    For my part, I use one of the jaws to setup my tools offsets. I take an 1/4"tool steel and I put it on the front of a jaw and I touch it with tools tips to setup my Z offsets of every tools. This way, I'm sure I'm setuping always the same way.
    I always use the G54 for the work offset. I have a TL-2 so no really use to have 3-4 work offset or use another one.
    I use the X work offset when tolerances are small. I put something like 0.01 and when the part is turned, I mesure it and I reajusted the X work offset to get to the final tolerance.
    Sep 2005
    28
    Well I am up and making parts with offsets and gang tooling. YAY
    Thanks to both of you have tried everything you mentioned and they helped to get things to click in.
    Is there a reason that the manuals from haas are so ****ty? I guess that they want you to pay someone to come over and show you the basic stuff, and charge out the ass for it...
    Does spindle orientation work on the TL-1 (in demo mode) ? I have to drill a bunch of small holes in the face of my part and it would be nice if I could rig something and do it all in one shot on the lathe rather than a seprate step on the mill..
    Thanks again, sometimes I just need a smack in the head to get things going.
    Chad
    Jul 2005
    12177
    ...Is there a reason that the manuals from haas are so ****ty?...
    Chad
    If a manufacturer put out a manual that was easy to understand and helpful in every aspect I think the universe might be upset by the shock this would cause. Seriously though; have you ever written an instruction manual for the use of your products? I have, all 250 pages and I can tell you it is hard to write clearly and include everything without causing some confusion to some people. The big problem is different people are confused by different aspects and if you change things to appease one group of critics then some other group do not like what you did.
    Regarding spindle orientation if there is a T beside the Parameter that has to be changed then you get the 200 hour trial. It is not as accurate or rigid as a mill of course; the orientation is just electronic.
  1. noob needs some help here!
    By foxpt in forum Stepper Motors / Drives
    Last Post: 07-16-2007, 10:51 PM
  2. yet another noob
    By mastermoparman in forum Community Club House
    Last Post: 09-18-2006, 07:22 AM
  3. yet another noob
    By mastermoparman in forum Uncategorised MetalWorking Machines
    Last Post: 09-15-2006, 12:24 PM
  4. NooB Needs a little Help
    By js11110 in forum DIY CNC Router Table Machines
    Last Post: 03-21-2006, 12:41 AM
  5. I know, I'm a noob...
    By WilliamD in forum CNC Machine Related Electronics
    Last Post: 10-08-2005, 02:19 AM
