586,058 active members*
4,260 visitors online*
Results 1 to 6 of 6
    Mach 3 scaling issue
    Hey all, I bought a cnc recently and "upgraded" it to Mach 3. It was used and iv rewired the entire thing added a Mach control board ect. I'm running Nema 23s on all axis, ball screw is 1 inch I Believe. Current tune for each motor is set to 600 steps, 239 velocity. This is just a randomized figured Iv put in to test the machine. Mach is set in inches, I have about 7inches of plunge on my z, however instead of reading - 7. 000 it reads like -189.00. Which is more closer to mm scale. How can I get this to accurately display an inch scale? Is this a motor tuning issue? Eg 600 steps is equivalent to 239mm? Would I just have to do the math conversion and set it accordingly? Or is there another set up page in Mach that I missed?
    Feb 2021
    Re: Mach 3 scaling issue
    Our specialist team provide a 24/7 emergency Residential locksmith houston service. An unexpected break-in is a distressing time and leaves your house even more vulnerable, thus we aim to maintain your premises within half an hour of your first call. Your safety is a priority priority for Locksmith in Houston; regardless of what scenario you’re stuck at, our specialists are ready to help you at every hour of the afternoon for an inexpensive price.
    Emergency Residential locksmith
    https://magnetlocksmith.com/commercial-locksmith/
    First, go to Config > Native Units. Set to inches, and restart Mach3.
    Then set the steps/unit accordingly, entering the number of steps required for 1" of movement.
    Note that if you use G21 to switch to metric mode, the DRO's will display mm's instead of inches.
    Thank you will try this tn.
    Mar 2022
    Quote Originally Posted by Ravikumar05169 View Post
    This locksmith service was the worst I've ever had. The locksmith came with a 2 hours delay, the work was done really bad and I got a lot of scratches on my door and the lock. More than that, the door is now closing even worse as it was before. I was told to call key cutting wembley for a better locksmith experience and it was 100% the best option I could ever have. That locksmith service was the best I could ever have and gladly the work was done clean, and now the door is closing perfectly, the locksmith took a look at all the locks inside my house and he pointed me at those that might have an issue. This means a real professional
    Mar 2022
    Quote Originally Posted by HelenBr View Post
    Agree! This service is much better! I had to deal with locksmith wembley, the locksmith came in 2o minutes and the work was done in 15. Brilliant
  1. Mach 3 Scaling Help
    By Kev Brook in forum Mach Mill
    Last Post: 03-23-2018, 12:08 AM
  2. LaserCad / AWC608 micro-issue : Scaling
    By Nickwit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-06-2014, 04:41 AM
  3. NM-145 Mach 3 Gcode scaling error?
    By CNCwilson in forum Novakon
    Last Post: 03-03-2011, 04:30 AM
  4. Mach 3 scaling issue? not sure if its machine.
    By CNCwilson in forum Mach Software (ArtSoft software)
    Last Post: 07-12-2010, 08:51 PM
  5. Scaling Issue
    By obie1 in forum Hobby Discussion
    Last Post: 10-10-2004, 12:57 PM
