586,260 active members*
2,860 visitors online*
Results 1 to 10 of 10
    Mar 2021
    6
    Help Required!
    Hi total newbie looking for advice, we have a cnc cam tech laser etching machine which was new on 27 sept 2001. One of the motor drives is beyond repair. We are looking to put in new drivers and motors. Can anyone help with advice as where to start. Even better if someone could do the job for us, or is local to Cheshire in the UK who would be willing to have a look at the machine and advise accordingly.?
    I have attached some photos and apologize if this post is in the wrong section.
    Apr 2005
    304
    Re: Help Required!
    And your motors are (size, winding current)?
    If you are willing to do it yourself, buy Leadshine DM542 drivers ( https://kitaez-cnc.com/f/dm542.pdf ) and, if needed, new steppers
    Manual for your drivers: https://www.kollmorgen.com/sites/def...ive_Manual.pdf
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Mar 2021
    6
    Re: Help Required!
    Hi thanks for the quick response.. will the motors have a stamp with the information on them or will I need to be looking else where?
    The MD 808 steppers are now obsolete, hence the reason for the upgrade.. the machine is 20 years old...
    The software has been upgraded and laser tube has been serviced, we would now like to upgrade the CNC bed.
    Apr 2005
    304
    Re: Help Required!
    The reason why I mentioned Leadshine drivers is Slo-Syn obsolesce.
    Just obtain Leadshine drivers and configure them as were your Slo-Syn drivers, i.e. Current and Microstepping.
    I guess that your motors are in good condition.
    Nov 2008
    643
    Re: Help Required!
    Just in looking at your images this drive has a signal called opto (haven’t seen that before) that appears to be positive to the control signals. Electronics knowledge might be needed with some other drive.
    You also need to consider the step resolution and amp settings. If the resolution changes then you need to make software adjustments that might or might not be easy to do. Resolution changes the machine scale.
    Is it possible to find a used drive on eBay?
    Apr 2005
    304
    Cool Re: Help Required!
    Hi Dean,
    (take a look at the manuals that I've linked in my post)
    the easiest way is to print a couple of pages from the manuals and place it side by side
    Current settings - SloSyn: Page 4-4; Leadshine: Page 8
    Microstepping - SloSyn: Page 4-5; Leadshine: Page 7.
    As per the electrical connections equivalents are:
    OPTO - PUL+ and DIR+
    PULSE - PUL-
    DIR - DIR-
    Only difference is that one jumper wire is needed to interconnect PUL+ and DIR+ on Leadshine driver(s).
    If microstepping can be set as on the SloSyn driver, no software adjustments are needed.
    As can be seen from Gadge's pictures AWO and RDCE are not connected.
    Mar 2021
    6
    Re: Help Required!
    Thanks for the information, very helpful..
    Mar 2021
    6
    Re: Help Required!
    As we are upgrading our stepper drivers to the Leadshine DM542's we think we should also replace the motors.( Slo Syn KML091S - 103) .I have attached a photo of the ones we have ,looking for recommendations as to replacement motors, again any help would be greatly appreciated.
    Apr 2005
    304
    Re: Help Required!
    Ok, for that motor suitable driver would be Leadshine DM556. http://www.leadshine.com/uploadfile/down/dm556m.pdf
    Mar 2021
    6
    Re: Help Required!
    Hi.. we would like to replace the drivers (MD808) and the Motors KML091S - 103 with a newer equivalent if possible so looking for a suitable replacement for both.?
    DM556 with compatible motors or DM542 with compatible motors?
  1. Help required please
    By powely in forum MetalWork Discussion
    Last Post: 09-21-2016, 12:15 AM
  2. HELP REQUIRED
    By diddly-squatt in forum Want To Buy...Need help!
    Last Post: 10-06-2015, 06:15 PM
  3. Help required
    By Summer5 in forum G-Code Programing
    Last Post: 02-10-2010, 11:50 AM
  4. help required
    By willheg in forum Stepper Motors / Drives
    Last Post: 12-14-2009, 11:41 PM
  5. Replies: 2
    Last Post: 12-06-2008, 03:10 AM
