586,103 active members*
3,534 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Centurion 6 SBC Issue with Display
    May 2016
    9
    The issue just occurred today. I attempted restarting and reseating the display connections. The screen displays in full during boot up. Then goes to partial screen for Operation. Pic attached. Any ideas what to look at first. Thanks in advance.
    Eric
    Apr 2008
    21
    I think I've read that the screen resolution/size can be changed in the power parameter menu.
    If there's no joy there get ahold of sportybob.
    May 2016
    9
    Re: Milltronics Centurion 6 SBC Issue with Display
    Lucked across this while searching this forum. I have a keyboard on the way. I need to search cmos battery repair now.
    https://www.cnczone.com/forums/millt...-problems.html
    Apr 2008
    21
    Sportybob swapped out the battery on mine. He soldered in a holder for a standard 2032 (i think). The turn around was quick and the price was quite reasonable.
    There's apparently a couple different types of "stock" batteries.. One easily replaceable and the other not so much. Luckily mine was the easily replaceable version.
    May 2016
    9
    Luckily mine is in a replaceable style holder. I have a battery on the way. I went thru and took pics of the parameters and I think I have the factory floppy with backup files.
  1. Replies: 3
    Last Post: 08-06-2018, 01:00 PM
  2. Milltronics Centurion IV DNC?
    By papp101 in forum Milltronics
    Last Post: 01-04-2014, 03:57 AM
  3. Milltronics 3 axis Centurion 6
    By Chizel in forum GibbsCAM
    Last Post: 05-04-2010, 05:25 PM
  4. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
