586,042 active members*
3,731 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > can possible convert cnc to Native Hand Engraving?
    May 2011
    6
    In my cnc machine is 1.5kw 24000rpm spindle X=100MM Y=200mm Z=80MM Fully aluminum Frame.
    Engraving metal with 0.1mm, 0.2mm , 0.5mm 30 Degree Engraving Bit using. its good.
    but i like Native Hand Engraving .
    can possible convert cnc do this work like this?
    https://www.youtube.com/watch?v=zlQjMCT0GWQ
    i think....
    XYZ with A Axis Enough.
    its possible , but how can do?
    which software process G Code like this?
    thanks.
    Apr 2004
    5737
    Re: can possible convert cnc to Native Hand Engraving?
    I suppose you could build a machine that could emulate hand engraving. You'd need to make a holder for a graver that would rotate according to the direction of the lines it was cutting; a rotary axis parallel to Z could do that, probably using a rotary table with a planetary gear where the spindle normally is mounted. You'd need specialized CAM software, though, that could analyze each letter or line you want to cut and command the rotary axis to keep the graver perpendicular to it while tracing the letter in X and Y and changing the height in Z to control the depth of cut and line thickness. It's possible that software like that exists, although I've never heard of it. If not, maybe you could find someone to write it for you.
    Andrew Werby
    Website
    May 2011
    6
    Quote Originally Posted by awerby View Post
    Thanks for Answer.
    but i am still waiting for software solution.
  1. Woodworking Engraving Machine VS Hand Engraving
    By FORSUNCNC in forum Uncategorised WoodWorking Machines
    Last Post: 02-20-2021, 09:43 AM
  2. Replies: 0
    Last Post: 09-01-2014, 07:00 AM
  3. Shimming a hand piece as engraving spindle
    By braddo in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2014, 06:07 PM
  4. MACH3 4 AXIS CNC Hand Wheel For ModsMach3 Engraving Machine MODBUS MPG Pendan
    By kunte in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2012, 03:12 PM
