586,036 active members*
3,793 visitors online*
    Aug 2011
    252
    4 axis display problem
    I`m new to TNG so be kind with me.
    I have a problem with displayed toolpath in 4 axis.
    When work coordinate is the same as machine display is ok.
    Attachment 460464
    When work coordinate is offset from machine coordinate it distort the toolpath like this:
    Attachment 460466
    In the old softare with offset didn`t had this problem:
    Attachment 460468
    The toolpath work without problems only it is displayed incorrect.
    If disable rotary axis in display 3d toolpath display is correct and not distorted, but not 3D.
    I hope I explained well the problem, if not I`m here for any clarifications.
    Aug 2011
    252
    Re: 4 axis display problem
    I really need an answer and solution because in 4 axis toolpaths, things get worse.
    Here is an example of 4 axis toolpath displayed on only 3 axis on TNG.
    Attachment 460518
    Aug 2011
    252
    Workaround for this is for now to copy a profile with machine in simulation and load toolpath in machine position, aka work position to machine position to see toolpath displayed correctly, then I can load toolpath in real profile for machining.
    Here it is displayed correctly.
    Attachment 460524
    I hope this is a temporary solution, and it will be fixed soon.
    Mar 2017
    1312
    Send me these g-codes. I assume profile is the same.
    Aug 2011
    252
    Problem solved thanks to PlanetCNC support.
  1. 5 Axis 3D toolpath display problem
    By CaptainObvious in forum PlanetCNC
    Last Post: 02-12-2023, 03:48 PM
  2. 5-axis CNC Breakout board and problem with connection display module
    By lasek in forum CNC Machine Related Electronics
    Last Post: 05-23-2013, 09:52 PM
  3. problem with display of Z axis (TNC 121)
    By Aschi86 in forum HEIDENHAIN -> TNC
    Last Post: 10-08-2011, 11:47 PM
  4. 15i-M display problem
    By Aaron 1874 in forum Fanuc
    Last Post: 12-29-2009, 08:20 PM
  5. m-2 display problem
    By elmmachine in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-27-2009, 04:48 PM
