586,106 active members*
3,166 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Different voltages running in parallel wires
    Jan 2019
    5
    Hi all.
    I'm in the process of wiring up the electrical cabinet on my cnc mill conversion and have got as far as the E-stop.
    My question is simple but needs to be explained to make sense.
    I have 5vdc from the ESS for the software e-stop.
    I have 24vac from the contactor coils for hardware e-stop.
    I have a double pole e-stop switch which works great with the 5vdc on one pole and the 24vac on the other. It successfully works at shutting down both hardware and software using the separated test wires.
    Now the time has come to put it together and I want to locate the run and e-stop buttons at the front of the machine using about 2m (6ft) of 5 core cable. 2 of the cores will be used for 5vdc and an input pin of the ESS. The remaining 3 cores will be used for the 24vac back to the contactors.
    My question is. Is the 24vac likely to induce higher voltages in the 5vdc and input wires of the ESS control board?
    Cheers,
    J
    Jan 2019
    5
    Re: Different voltages running in parallel wires
    Never mind. I just thought of a different way.
    I can just use one of the spare contacts on the contactors to run the 5vdc from the ESS E-stop.
    Amazing what a bit of sleep will do.
    Aug 2009
    1573
    ...always mind the neverminds...almostly
    Nov 2012
    1267
    It is not a good idea to run 5V single ended signals anywhere outside the controller board. Definitely not in the same long multicore cable with 24VAC contactor coil wires. That would have very likely given you problems.
  1. My 4 wires Steppers, internally are the series or parallel?
    By Calibre41 in forum Stepper Motors / Drives
    Last Post: 01-04-2014, 07:42 PM
  2. Notebook pcmia parallel port card output pin voltages are not steady
    By EL34 in forum Machines running Mach Software
    Last Post: 10-05-2013, 11:27 PM
  3. Replies: 4
    Last Post: 12-18-2008, 05:59 AM
  4. Longer parallel cable or longer steper wires?
    By jvanick in forum Hobbycnc (Products)
    Last Post: 09-13-2008, 11:51 AM
  5. Question about +5V from pc and running wires
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 01-05-2005, 04:58 PM
