586,058 active members*
3,389 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > Supermax YCM-40 AB Bandit IV controller replacement
Results 1 to 2 of 2
    Apr 2021
    Hi all.
    I am purchasing an in "almost new" condition YCM-40 with an AB Bandit 4 controller. The mill has less than 40 hours on it. It has been in a garage for many years and never connected to power since the person bought it.
    Funny enough, the first controller I used was a Bandit 4.
    That said, it was great in 1988, but not so much now. Since the mill is in basically from the showroom condition, I am hoping I can take an easy path to getting it up and running.
    For power, I have a 10HP rotary phase converter that I plan to connect the mill to. Would there be any benefit to going to an VFD, since I already have the rotary converter?
    Does anyone have experience replacing just the controller on this style mill? I have it in my head to strip out the AB components, and replace with an Mach 3 or 4 PC and motion controller. I hope it will be this simple, but something tells me I'm dreaming and will have to do a lot more than simply take out old controller components and replace with new items. This is where I have absolutely no experience, and will be learning from scratch. Any info will give me a leg up!
    I pick up the mill Friday, so don't have specific info regarding servos, etc.
    Thank you!
    Dec 2013
    5717
    Re: Supermax YCM-40 AB Bandit IV controller replacement
    You might look at the Dynomotion Kflop/Kanalog controller. It might save you from replacing the drives and motors. This retrofit should be an easy one.
    I assume the drives are single phase and the only thing that requires 3 phase is the spindle motor. I would probably hang a VFD on it and eliminate the RPC. Lots of 3HP single phase input VFDs available.
    Jim Dawson
    Sandy, Oregon, USA
  1. Supermax YCM-TC-15
    By GTMondock in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2013, 04:22 PM
  2. SuperMax ycm-40
    By smorris in forum Knee Vertical Mills
    Last Post: 12-04-2012, 03:42 AM
  3. SuperMax ycm-40 Anilam M controller 1988
    By bobwood in forum Knee Vertical Mills
    Last Post: 12-28-2010, 02:47 AM
  4. SuperMax ycm 40
    By Tymco in forum Knee Vertical Mills
    Last Post: 07-24-2007, 03:46 AM
