586,096 active members*
3,378 visitors online*
Results 1 to 6 of 6
    Sep 2016
    9
    Matsuura MC-760V Spindle issue
    We have an old Matsuura MC-760V2 mill with a Yasnac MX2 control.
    Lately, at spindle stop (M05) or orient (M19) command usually for tool change, the spindle physically stops or orients, but the spindle run indicating light stays on, and the machine pauses sometimes from a few seconds to multiple minutes without alarm or error before continuing with the operation.
    Normally the spindle run indicator light turns off when the spindle stops. Even now it eventually turns off after the pause.
    I assume, that there is a switch or sensor that is malfunctioning.
    Would anyone be able to help us to troubleshoot, and locate the faulty item?
    Your help would be greatly appreciated.
    Oct 2008
    1632
    Re: Matsuura MC-760V Spindle issue
    And you posted in the Fadal forum???
    Sep 2016
    9
    I'm sorry. I did not realize that it was in the Fadal forum. Is there a way to remove it?>
    Oct 2008
    1632
    I don't think it bothers anyone. I only mentioned it because I figured you did it by mistake and most likely wouldn't get many responses.
    Dec 2013
    5717
    We don't have a Matsuura forum, so maybe this is as good as any.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    24221
    Incidentally i just moved it here.
    Albert E.
  1. Matsuura MC-760V tool change arm problem
    By ThomasBrown in forum Uncategorised MetalWorking Machines
    Last Post: 09-15-2017, 09:17 PM
  2. Matsuura MC-760V VMC
    By BuddyT in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2015, 02:45 PM
  3. Matsuura Tool Change Issue
    By wsm in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2014, 12:52 AM
  4. MATSUURA MC-760V, error code
    By MBfreak in forum Want To Buy...Need help!
    Last Post: 11-04-2011, 07:50 PM
  5. Matsuura 760V M5G control
    By marcov in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-02-2011, 12:27 AM
