586,072 active members*
4,602 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang HY01D511B - PD142 Motor Current setting
    Hi all,
    Recently received the Huanyang HY01D511B 110V - 1.5KW VFD. It is paired with a 110V/1.5KW/24000RPM 80mm spindle.
    I have everything setup, spindle spins just fine - even got it working w/ my controls so Mach4 can control it.
    One thing I can't figure out is PD142 Motor Rated Current - I can't set this to any value greater than 7.0A. Doesn't it need to be 13A? Also confusing is PD174 reads 7.0A - even though it clearly states in the manual it's 13A.
    What am I doing wrong? I've searched pretty extensively on the subject, I can't figure out why I can't increase the value of PD142.
    Any ideas?
    EDIT: Am dumb. Forgot about sqrt(3) in the 3PH motor current calculations. 1500w = (120V * I * 1.0PF * 1.732)....solving for I here = 7.27A. All good! I'll leave this here for anyone that has the same issue in the future.
    Re: Huanyang HY01D511B - PD142 Motor Current setting
    What is the rating stamped on the motor?
  1. Huanyang VFD Over Current Error EoCA
    By nates02gt in forum Spindles / VFD
    Last Post: 06-18-2023, 04:01 PM
  2. Huanyang VFD HY01D511B potentiometer issue
    By JackMath in forum Spindles / VFD
    Last Post: 10-31-2019, 01:26 AM
  3. Optimum current setting for stepper motor
    By 2418 in forum Stepper Motors / Drives
    Last Post: 03-26-2019, 09:02 PM
  4. Huanyang Powtran PI8600 Over current Alarm locks VFD
    By SparkyNL in forum Phase Converters
    Last Post: 04-07-2017, 11:49 AM
  5. Wiring 8-wire motor as bipolar series and setting current!
    By whitewittock in forum Stepper Motors / Drives
    Last Post: 07-13-2012, 09:29 PM
