586,035 active members*
3,814 visitors online*
Results 1 to 6 of 6
    Jul 2009
    152
    X negative to X positive
    Is there a way to change from X negative to X positive without placing the tool on the opposite side of the part?
    Mar 2021
    17
    Re: X negative to X positive
    You can multiply xpos by -1 before the output. For example:
    xpos=-1*xpos
    {nb, 'X'xpos}
    Be sure to check that it won't cause an accident before sending it to the machine!!!!
    Jul 2009
    152
    anzory, Thanks for that.
    Do I add this to the GPP or Find it in the GPP and modify it ?
    Mar 2021
    17
    Yes, it can be done. But I cannot guarantee that you will get a valid gcode. How will the arcs be built in this case? Chamfers? I can't predict that.
    You'll have to check it yourself before you load it on the machine.
    Mar 2021
    17
    To edit a post, use this: https://bit.ly/3fqkPD8
    Quote Originally Posted by anzory View Post
    xpos=-1*xpos
    {nb, 'X'xpos}
    I believe that will not work well even without arcs and such.
    You will end up getting a new X on every single line. Even if Modal and same number. As the check if it's the same will see a negative currently, and a positive incoming, so thinks it needs to state it again.
    Unless you see a way around that?
  1. Motor positive or negative ground
    By onthemarc in forum CNC Machine Related Electronics
    Last Post: 02-03-2018, 05:43 AM
  2. Negative & positive limit
    By ltran2000 in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-07-2012, 12:43 AM
  3. Y values negative instead of positive
    By Wayne Krammer in forum NCPlot G-Code editor / backplotter
    Last Post: 03-13-2011, 04:25 PM
  4. Lathe - X axis positive/negative?
    By sansbury in forum BobCad-Cam
    Last Post: 08-20-2010, 03:58 PM
  5. 5 volt positive and negative??
    By Rooney in forum Automation Technology Products
    Last Post: 05-07-2009, 10:04 PM
