586,108 active members*
3,174 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Auto Tool Zero button config problems in Mach3
Results 1 to 6 of 6
    Feb 2019
    9
    So I have been trying to set up my Auto Tool Zero button in Mach3. I am using the standard code found online. When I push the button the Z axis travels down and touches the touch plate as it should but then retracts and continues to go up out of the limits of the machine. It does not stop at specified location. I am not good at gcode and was hoping someone can help me sort this out. I will attach the code I am using.
    CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
    CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
    CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
    If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
    DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
    Code "G4 P3" ' this delay gives me time to get from computer to hold probe in place
    Code "G90 G31Z-1. F4" 'probing move, can set the feed rate here as well as how far to move
    While IsMoving() 'wait while it happens
    Wend
    ZProbePos = GetVar(2002) 'get the exact point the probe was hit
    Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
    While IsMoving ()
    Wend
    Call SetDro (2, .123) ' change .060 to your plate thickness and then adjust for final accuracy
    Sleep 200 'Pause for Dro to update.
    Code "G1 Z.5 F50" 'put the Z retract height you want here, must be greater than the touch plate thickness
    While IsMoving ()
    Wend
    Code "(Z axis is now zeroed)" 'puts this message in the status bar
    Code "F" &CurrentFeed 'Returns to prior feed rate
    Else
    Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if applicable
    End If
    If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
    Code "G91"
    End If
    If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
    Code "G0"
    End If
    Re: Auto Tool Zero button config problems in Mach3
    Are you using the parallel port, or a motion controller?
    If you have a Chinese motion controller, that code probably will not work.
    Feb 2019
    9
    Its a motion controller. Is there any code that will work for it? I am just looking at capturing the z axis zero. Like I said I'm not good with gcode
    Thanks for your reply
    Try getting rid of the GetVAR functions.
    Replace ZProbePos = GetVar(2002)
    with ZProbePos = GetOEMDRO(802)
    and then see if it works.
    Feb 2019
    9
    That was the ticket. Works perfect now. Thanks for the help, I woulda never figured that out on my own
    Sep 2003
    1469
    Glad to see that the Z zero is now working.
    Will this code work on the Mach3 Version I recently downloaded, in the lower center of the screen there is a Zero utility, would this code work with it? Here’s a photo
  1. Auto Tool Zero button
    By Richster in forum Mach Mill
    Last Post: 09-01-2019, 07:49 PM
  2. Question about Auto Tool Zero button.
    By jgomez in forum Mach Wizards, Macros, & Addons
    Last Post: 03-07-2019, 02:14 PM
  3. Auto tool zero doesn't stop in Auto Tool Zero routine on Mach3
    By Flintstone in forum WoodWorking Topics
    Last Post: 09-05-2017, 07:00 PM
  4. auto tool zero button not visible
    By Tonyi in forum Mach Software (ArtSoft software)
    Last Post: 03-09-2017, 11:02 PM
  5. Auto Tool Setter Button IH taylored !
    By Cruiser in forum Charter Oak Automation Support Forum
    Last Post: 08-06-2009, 03:25 PM
