586,269 active members*
3,295 visitors online*
    Haas editing question
    How do I "find and replace all" in program, at controller, on Haas mill? (i.e. replacing multiple F283. with F100. But don't want to do it one at a time).
    Mar 2010
    1852
    Re: Haas editing question
    Go to your program and hit edit. That will bring up the program in a smaller box and a list of available functions above. Press F1 and that will bring up the sub functions. Arrow over to SEARCH and hit and hit the WRITE/ENTER button. (that's the button on the far right lower corner of the panel.) There is an offered function that says something like find and replace. Hit the WRITE/ENTER button again. Just kind of follow the instructions from there. It will ask you to select the text you want to replace ans enter the text you wish to replace it with. It will ask you if you want to change that one or all. If you choose all "A", it will replace of that match.
    Good luck-----Mike
    Quote Originally Posted by Machineit View Post
    Good luck-----Mike
    Thanks Mike
  1. Question about text editing after posting
    By Bigums in forum GibbsCAM
    Last Post: 08-10-2015, 05:04 PM
  2. Replies: 6
    Last Post: 04-29-2014, 10:52 PM
  3. Solved---Node editing question
    By JC50 in forum ArtCam Pro
    Last Post: 02-22-2013, 07:58 PM
  4. Editing question
    By cncadmin in forum OneCNC
    Last Post: 10-23-2004, 05:09 AM
