586,111 active members*
3,148 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Matching stepper driver to motor (motor current equal to the driver maximum current)
    Jul 2016
    5
    I have a two-phase bipolar stepper motor rated on 4.2 amps per phase (parallel connection). The peak current draw for this motor: 4.2 A * sqrt(2) = 4.2 * 1,41 = 5,92 A.
    I'm looking for a matching stepper motor driver and I'm considering two options:
    a) 2DM556S - it is rated for maximum of 4.2 A (RMS) = 5.88 A (peak)
    (manufacturer assumes that sqrt(2) = 1.4, so 4.2 * 1,4 = 5.88 A)
    https://www.cnczone.com/forums/attac...d=460784&stc=1
    b) 2DM860H - it is rated for maximum of 6.0 A (RMS) = 8.40 A (peak), so absolutely no problem running this motor, but the cost is twice as high, compared to the 2DM556S.
    https://www.cnczone.com/forums/attac...d=460788&stc=1
    On a first glance, this 2DM556S driver would match my motor (same peak current draw), but is it a good idea to run the motor on the maximum possible setting of a driver (is it safe for the driver itself or would I be risking its damage in the longer period of time)? Should I pick a driver with a higher maximum peak current?
    Jul 2018
    6341
    Re: Matching stepper driver to motor (motor current equal to the driver maximum curre
    Hi XA - The driver is current limited so you can't draw more then the driver can produce. So its safe to use the 556S. For best performance run it at 48V. The 860 can be run up to 80V so it should be able to run faster if you need speed, that's the main reason its dearer it has to have higher rated parts.... . cheers Peter
  1. simple matching stepper motor to the driver
    By alihureiby in forum Maintenance DIY Discussion
    Last Post: 03-19-2017, 06:59 PM
  2. KL-4030 Bipolar Stepper Motor Driver Dip Switch Current Mode
    By CStevens6 in forum Stepper Motors / Drives
    Last Post: 09-20-2015, 04:07 PM
  3. DRIVER CURRENT SETUP - MOTOR RATED CURRENT
    By kmin in forum Stepper Motors / Drives
    Last Post: 08-28-2015, 12:17 AM
  4. Current Limit Formula for Pololu A4988 Stepper Motor Driver Carrier
    By Josiah in forum CNC Machine Related Electronics
    Last Post: 04-22-2014, 06:00 PM
  5. DIY 5 phase stepper motor driver, constant current question
    By clintonedward in forum Stepper Motors / Drives
    Last Post: 04-13-2014, 03:10 PM
