586,071 active members*
3,949 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Enclosure for Gecko 540 and SmoothStepper - both in same box?
    Aug 2009
    119
    Electronics newbie - I'm upgrading an old Techno Davinci router with a Gecko G540 drive and an ESS Smoothstepper. Wondering if there's any reason not to put them both in the same enclosure? I'm using the original power source in the Davinci, which is mounted in one of the gantry uprights. The gantry is fixed, the table moves, so I am planning to bolt the box to the side of the gantry
    Also would like to have a 120v relay to turn on the router motor, can that also be in the same enclosure?
    My concern is whether there are any noise problems with any of these components that require isolation.
    All and any advice appreciated, thanks
    Richard
    Jun 2013
    443
    Re: Enclosure for Gecko 540 and SmoothStepper - both in same box?
    I asked the same question. Same box. Way to go. Just lay it out before you buy..... nothing worse than not fitting it all in lol
    Sent from my SM-N970F using Tapatalk
    Aug 2009
    119
    Thanks, thought as much.
    What about the relay, cn that be in there also?
  1. Gecko G540 + SmoothStepper with mach4
    By geroge in forum Mach Software (ArtSoft software)
    Last Post: 04-01-2019, 08:19 AM
  2. CNC USB Kit - SmoothStepper, Gecko, PMDX, Mean Well
    By ttjarrett in forum For Sale Only
    Last Post: 01-05-2015, 02:15 AM
  3. SmoothStepper, Gecko Drives, PMDX BOB, Power Supplies
    By thegolfer in forum For Sale Only
    Last Post: 06-26-2014, 09:10 AM
  4. Gecko g540 and SmoothStepper USB
    By mikenz in forum Gecko Drives
    Last Post: 05-28-2013, 11:10 PM
  5. gecko g540 and smoothstepper
    By pabney in forum Gecko Drives
    Last Post: 08-01-2012, 10:42 PM
