587,013 active members*
3,694 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Position of thrust bearings on ballscrew
    Oct 2006
    44
    Question Position of thrust bearings on ballscrew
    I'm converting an X3 mill to CNC and have been doing a bit of brainstorming which has thrown up the following query:
    I'll be driving my ballscrews with stepper motors coupled via oldham type couplings.
    I need to incorporate some thrust arrangement, preferably a pair of angular contact ball bearings configured back to back - but I don't want to increase the overhang at the drive end any more than absolutely necessary as the steppers are pretty large components.
    Is mounting the thrust bearings at the non drive end of the ballscrew a bad idea?
    Aug 2007
    147
    Yes.
    Thermal expansion will put axial stress on the motor and bearings. Keep them on the same side.
    Oct 2006
    44
    I know that is the conventional approach but the reason I ask is that If my calculations are right, 500mm of ballscrew raised from 20 to 60 deg C gives a total expansion of around 0.25mm in the worst case - assuming there is no rise in temperature of the ballscrew mounting i.e. the mill table / Y axis structure is held at 20 deg.
    (the coefficient of expansion of mild steel at around room temperatures being 11.1 µm/m -°C, rising to 17.3 for stainless)
    I can easily allow for end float in the oldham coupling of twice that without compromising the integrity of the coupling.
    Aug 2007
    147
    You are correct, there should be no problem at all with that particular coupling.
    For some reason, I had a picture in my mind that an Oldham coupling was similar to a rigid coupling rather than a lovejoy coupling.
  1. Replacing thrust bearings yourself?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-27-2006, 11:26 PM
  2. Needle thrust bearings
    By cncuser1 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-18-2006, 12:13 PM
  3. Thrust Bearings
    By chas in forum DIY CNC Router Table Machines
    Last Post: 08-06-2004, 12:07 AM
  4. Thrust bearings
    By CactusChip in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2003, 07:37 AM
  5. Thrust Bearings
    By ToyMaker in forum DIY CNC Router Table Machines
    Last Post: 07-07-2003, 05:24 AM
