I received my NEMA 12, 16" x 20" x 6", steel enclosure box from www.automationdirect.com yesterday. I will be making my own sub-panel for it, to suit.
I also got the shielded encoder cables from www.usdigital.com. I finally got around to installing the encoders on the servo motors.
My main focus in the last few days has been gathering all of the little pieces and parts like wire, fuses, fuse holders, terminal strips, switches, etc.
I also got around to installing a 2 HP 3-phase motor, and a Hitachi L200 VFD on my 17" vertical wood cutting band saw. Now I have the ability to
cut either wood or metal, adjusting the speed as needed.
The conversion / install was a lot easier than I thought it would be. I should have done it a long time ago, as I have needed a metal cutting band saw many a time in the past. The hardest part was boring out the hole in the "V" pulley from .625 to .875, to accomodate the larger shaft on the new Baldor motor. I also had to transfer, drill and tap four M8 threads into the front of the motor housing to suit the pivoting motor mount plate from the stock motor.
I purchas both the VFD and motor from www.driveswarehouse.com. They seemed to have just about the best prices that I could find.
