586,069 active members*
3,826 visitors online*
IndustryArena Forum > CAD Software > Autodesk > AutoCAD 2018 DXF file curves are faceted in Mach3 and Easel
Results 1 to 9 of 9
Threaded View
    Mar 2021
    5
    In AutoCAD 2018, I made a simple drawing , a U shaped 3 sided drawing, with the 4th side a curve of radius 150mm. Save as a dxf file and a pdf file showing the dimensions ( see attached).
    In AutoCAD, in DWG TrueView and in DWG FastView, and in DWGSee Pro, the curve is very smooth, no sign of any faceting.
    When this DXF file is imported into Mach3, the end result is a faceted curve, and the CNC router cuts it like that.
    When the DXF file is imported into Easel (see Inventables.com), the faceted curve appears again , as per the attachment CNC Image.pdf
    Can anybody please advise what might be happening to make these faceted curves appear, and the best way to prevent it and get a smooth curve on the CNC router?
    kind regards to all,
    Joe
    Attached Files Attached Files
  1. Solidcam 2018 Mach3 Sim.5 axis
    By atekinay in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-10-2020, 03:56 PM
  2. Logic Trace 2018 file that I will show a simple node edit
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 10-07-2018, 01:34 AM
  3. logic trace 2018 saving in variuos file formats
    Last Post: 09-30-2018, 08:24 PM
  4. Replies: 25
    Last Post: 09-16-2013, 03:44 AM
