586,043 active members*
3,574 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > puma mx2100st spindle warm up alarm
    We began getting a spindle warm up alarm after running most of day. Will run a spindle warm up and still get alarm unable to manually start spindle. Powering down machine and starting back up helps from time to time. any suggestions as to what can cause this?
    Jul 2017
    Re: puma mx2100st spindle warm up alarm
    Check keep relay K13.4 (KNSPW): Milling spindle warming up function is not available (1), or is available (0). This won't fix whatever is causing the issue but it might get you going until you can get it fixed properly. Also, I'd confirm that keep number by checking in your blue book, should be in the pocket in the electrical cabinet door.
  1. Spindle warm up script
    By bobmagnuson in forum Mach Software (ArtSoft software)
    Last Post: 10-26-2018, 01:00 AM
  2. Puma 6 spindle alarm
    By tfuqua63 in forum Daewoo/Doosan
    Last Post: 02-01-2017, 04:59 AM
  3. puma 250 turret is getting very warm
    By BJ100 in forum Daewoo/Doosan
    Last Post: 11-11-2014, 06:08 PM
  4. Should i warm up the spindle
    By samu in forum Bridgeport / Hardinge Mills
    Last Post: 04-01-2010, 01:14 AM
  5. Fadal Spindle getting warm
    By beyegladcnc in forum Fadal
    Last Post: 06-18-2008, 01:50 AM
