586,242 active members*
3,601 visitors online*
IndustryArena Forum > CAM Software > Vectric > Bill's second Lithophane with a twist...
Results 1 to 8 of 8
    Sep 2005
    116
    I was cutting a lithophane the other day and after finishing the rough cut I broke my 0.031 ball nose bit after just a couple of passes (lower right hand corner of lithophane). Last night it dawned on me that my five dollar 45 degree V-Groove bit might work. (the ball nose cost $40 and is not available locally) So I tried it using the G-Code for .031 bit... and Eureka!!!! It works!!
    So because I am too cheap to throw out a 1/2 cut piece of Corian I have discovered that I can cut the lithophane with a 45 degree bit with the settings for a .031 bit, but at a higher speed AND it looks better too. The detail is much finer with the V bit than with the ball nose! I need to find a 20 degree V-bit next...
    What do you think?
    Bill Schober
    Pine Grove, California
    Attached Thumbnails Attached Thumbnails Eagle_002_FL_sm.jpg   Eagle_002_BL_sm.jpg
    Dec 2006
    77
    Nice work, keep us informed of your trials with the 20 degree bit. I also do litho's with expensive bits.
    Brian :cheers:
    Sep 2005
    116
    I am cutting a new Lithophane without the rough cut using the 45 degree V-bit only.
    So far it is cutting perfectly...
    The text file is nearly 40 MB!
    It has far more complicated details.
    I will post it tomorrow.
    :wee: :wee:
    Bill
    May 2006
    2420
    Litho's are definately on my list of things to do before I die Nice work again Bill.
    Russell.
    Aug 2004
    3215
    what was the settings used? cut time etc.?
    Joe
    Oct 2005
    672
    Very nice detail. So far, I've roughed with a 1/8" ball endmill and finished with a 3/64" ball endmill. I've been thinking about getting a 1/32" or smaller ball endmill but maybe a v-bit would be better.
    Apr 2005
    438
    That looks great!!!! And Joe2000che already ask my follow up questions.
    Sep 2005
    116
  1. My 1st Lithophane...
    By bsimages in forum Vectric
    Last Post: 12-28-2013, 06:53 PM
  2. Lithophane
    By Donald in forum WoodWorking Topics
    Last Post: 11-23-2013, 03:44 AM
  3. DIY with a twist or a turn
    By M08M09 in forum DIY CNC Router Table Machines
    Last Post: 02-14-2007, 02:18 AM
  4. Drill holes with end mill or twist drill ?
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-30-2006, 05:05 AM
  5. New Twist on Wire Management
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 04-30-2003, 09:34 PM
