586,069 active members*
3,667 visitors online*
    Apr 2012
    79
    Robodrill T14ia Schematic
    Hi, Can anybody help me with a schematic for a Robodrill T14iA. I am having issues with the machine not turning off after it has been on for a while and am trying to locate the relay that actuates the main contactor. Machine comes up with a KM1 weld alarm which id the main contactor. Any help would be very much appreciated.
    Aug 2011
    15
    Re: Robodrill T14ia Schematic
    Attachment 462006
    as you can see in the picture
    X20.7 needs to go off to switch off, so you need to check this input
    also when KM5 is energised it latches itself on, so make sure ON switch is not sticking in
    when you switch off check you have output from Y23.6 which operates KA12 which in turn releases KM5
    hope this helps
  1. Replies: 0
    Last Post: 09-15-2020, 05:33 PM
  2. Replies: 2
    Last Post: 09-12-2019, 12:56 AM
  3. 252 ATC alarm robodrill T14iA
    By jorgehrr in forum Fanuc
    Last Post: 07-28-2015, 08:07 PM
  4. Fanuc T14IA Robodrill Need Sample Programs
    By gorillam in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2010, 09:29 PM
  5. Fanuc t14ia robodrill post
    By binzer in forum GibbsCAM
    Last Post: 02-11-2007, 10:28 PM
