586,032 active members*
2,962 visitors online*
    Mar 2021
    CNC 3018 PRO, adding laser
    Hello.
    I'm interested to start with CNC, so I'm looking for CNC 3018 as start machine.
    I was curious, if i buy CNC 3018 without laser engraver, can i add any laser to it in future?
    Thanks for help in advance!
    Apr 2004
    5737
    Re: CNC 3018 PRO, adding laser
    I don't think that's a good idea; lasers are dangerous. Even a laser pointer can blind you, but cutting lasers are a lot more powerful. All it has to do is hit something shiny to bounce back in your direction. There's a reason that laser cutters are totally enclosed in special glass, with safety interlocks that cut power when the door is opened.
    Andrew Werby
    Website
    Mar 2021
    35
    the sainsmart 3018 pro is a good machine worth the investment.
    Regarding the laser it does not make a differance if you included in the original purchase or not. You always can go back and buy it separatly
    May 2004
    210
    You can retrofit a laser to the typical 3018 machines. Just be aware of the laser module size and whether it will fit in the motor mount of your machine. Some the laser modules are too small and will need some shimming to make them fit.
    As to safety. Yes, you should put it in a case but don't need special "glass", any acrylic that blocks blue will be safe. Look at laser enclosures online for some ideas. I built one for a 3018 I converted to laser. It cost about about 50 USD but you can get by with cheaper by only having one window. I used orange translucent acrylic on top, front and sides.
  1. CNC 3018 Pro _ Help needed
    By telteknv in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-19-2022, 02:24 AM
  2. Is 10W laser safe on 3018 pro CNC?
    By RobboRobbo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-29-2020, 09:49 PM
  3. My 3018 CNC Pro Project
    By cjdawson in forum CNC Machine Related Electronics
    Last Post: 04-11-2020, 04:46 PM
  4. CNC 3018 PRO _ Help needed
    By telteknv in forum Chinese Machines
    Last Post: 04-11-2020, 03:36 PM
  5. Replies: 4
    Last Post: 10-17-2019, 08:42 PM
