586,475 active members*
3,434 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HELP 2001 Haas Mini Lathe Shutting down....
    Mar 2015
    I bought a used mini lathe 2001 with very low hours. When I try to spin the spindle up to 3k or higher the machine suddenly shuts off and re boots. No alarm in the history! I ran #6 wires about 100 feet to the machine. So I think I'm good on wiring but acts like a brown out. Help please?
    Oct 2022
    4
    Quote Originally Posted by dpientak View Post
    I'm having the same issue on my SL20 after recovering from a dead backup battery.
    -John
    15362
    Re: HELP 2001 Haas Mini Lathe Shutting down....
    You would have a 20% voltage drop over 100 Feet, what is the machine Name plate amp requirement this is what you have to have at the machine, a #6 is good for 55A, so you most likely are right on the edge of not enough supply Voltage when ramping up to full speed try going up very slowly small steps and see if it can get to max RPM
    Mactec54
    15362
    Quote Originally Posted by John_Kay View Post
    -John
    That could be that a Parameter is not set correct after battery replacement, and could be the OPs problem also
    Mactec54
  1. Adding a 4th axis to 2001 Haas Mini Mill
    By ChuckHackett in forum Haas Mills
    Last Post: 11-21-2019, 12:24 AM
  2. 2001 Haas Mini Mill Way Lube Adjustment?
    By Terry G in forum Haas Mills
    Last Post: 06-28-2012, 10:50 AM
  3. 2001 Haas SL-20 lathe vibration??
    By gixxergary in forum Haas Lathes
    Last Post: 04-09-2011, 04:26 AM
  4. No Interrupt alarm on 2001 Haas Mini Mill?
    By JasonR in forum Haas Mills
    Last Post: 08-01-2010, 07:06 AM
  5. HAAS mini lathe
    By marto74 in forum Haas Lathes
    Last Post: 01-15-2004, 06:55 PM
