586,061 active members*
4,453 visitors online*
    Jul 2018
    8
    parameter edit screen lock
    how to do password protect for fanuc series Oi-TD parameter edit screen lock even though PWE in MDI mode from zero to one. At present soft limit for x axis and z axis in CNC centerless grinding is edited by shopfloor operators which is not a good practice.
    Aug 2018
    44
    Re: parameter edit screen lock
    not so complicated
    Need to modify PMC control using key 2 fonction
    You set parameter 3299.0 (PKY) then PWE becomes protected. The only way to un protect it is to change 3299.0 back to a 0. This has to be set on the settings page where PWE is. You just page down till you find it.
