586,477 active members*
3,134 visitors online*
    Mar 2007
    114
    Machine Serial Number
    Had to re-initialise the machine after total loss of parameters due to no battery. Have replaced the battery and set the machine type using Debug. Loaded up the backup but have noticed setting 26, machine serial number is corrupt. Does anyone know if this matters or how to correct it ?
    Jun 2008
    Re: Machine Serial Number
    Quote Originally Posted by rrbmachining View Post
    If the serial number is incorrect it will affect what options are turned on. Also after 900 hours you will need to put in an unlock code. If the serial number is incorrect the correct unlock cannot be generated. So the machine will be down.
    There is a series of codes you can type in, in engineer mode which will clear the serial number and allow you to put the correct one in. However you will need to put the parameters and settings back in as well
    Where in the UK are you based
    Mar 2007
    114
    Quote Originally Posted by mclark View Post
    I'm in Essex, I am thinking about totally reloading the machine as I think something corrupted when loading. The machine type was not set in debug mode when I reloaded all the parameters and settings
  1. serial number of the machine
    By zac69 in forum Kitamura
    Last Post: 09-05-2017, 07:43 AM
  2. Need help with ID part serial number on CNC producton machine
    By JamesZhao in forum European Club House
    Last Post: 08-06-2016, 10:57 PM
  3. serial number engraving with SS machine
    By mwestvang in forum Shopsabre
    Last Post: 03-06-2014, 03:52 PM
  4. Replies: 20
    Last Post: 03-21-2012, 11:47 PM
