586,112 active members*
2,931 visitors online*
    Jan 2018
    Question strange Y axis problem on Gerber CNC
    Hi all. i need some help here. i got an old Gerber machine. still has original screw and rail. motor has upgrade to AC servo. Running Mach 3 now. machine is rigid, push gentry with no movement. now here is the problem. when i cut 2000mm, i get 2000mm sport on no problem. cut 800mm, get 799.70mm. 0.3mm off. cut 50mm. get 49mm, 1mm off. change step setting to make 50mm cut perfect. when cut 2000mm, gets 2008mm. i am confused. really dont know where to start. Please help. thanks (PS. this machine running fine before, all sizes cuts perfect. this is not a new build problem.)
    Dec 2013
    5717
    Re: strange Y axis problem on Gerber CNC
    Measure your cutter. It may not be exactly on size, maybe small?
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2018
    31
    Hello, you mean its a laser or a cnc machine ?
    Nov 2012
    1267
    Quote Originally Posted by Syx1977 View Post
    Here is your problem. "Steps per unit" is not something you change, adjust or tweak. It is a hard number that you calculate from your screw/motor parameters, set once and never touch again.
    Set the number where it was before and look for another issue. It could be, as Jim said, incorrect cutter diameter.
  1. Gerber Dimension 200 Y axis problem
    By packratcnc in forum Uncategorised WoodWorking Machines
    Last Post: 12-04-2016, 03:44 PM
  2. Strange problem with moving X axis all of a sudden
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-27-2013, 10:24 PM
  3. Z axis-encoder-motor problem on Gerber Saber
    By vipers95 in forum Commercial CNC Wood Routers
    Last Post: 04-09-2009, 05:49 PM
  4. Strange Axis problem after Ballscrew Change
    By AKFALAR in forum CamSoft Products
    Last Post: 04-01-2009, 10:07 PM
  5. CNC strange problem
    By huben_123 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-15-2008, 12:12 AM
