586,269 active members*
3,604 visitors online*
    4" oal 1/4" shaft cnc end mills anywhere?
    I am trying to find 2-3 flute 4" oal 1/4" end mills and I'm not finding any. Anyone have a reputable source? My machine runs about 320ipm. I am cutting hardwood by the way.
    bonus points if any finds 1/8" as well but with 1/4" shaft
    Dec 2013
    5717
    Re: 4" oal 1/4" shaft cnc end mills anywhere?
    Google long endmills
    You can get them in even crazy long lengths, many vendors available.
    Lots of combinations of OAL and cutting lengths.
    Harvey Tool has just about anything you could want.
    Jim Dawson
    Sandy, Oregon, USA
    Thanks, harvey tool had one of the bits but I realized that you can just ask a distributor to request a longer version.
    Aug 2005
    205
    I'm curious to know if you've been able to cut at that rate in hardwood with the cutter fully extended? Or are you just cleaning up the cut.
  1. "Face milling" with end mills (workpiece is smaller than end mill dia.)
    By hav0c in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-24-2014, 02:13 AM
  2. Replies: 0
    Last Post: 02-04-2014, 02:06 AM
  3. Looking for 3.5-4" OAL 1/4" to 1/2" diameter Ball endmills.. anyone?
    By rhadiem in forum Uncategorised WoodWorking Machines
    Last Post: 02-01-2014, 11:17 AM
  4. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
