586,119 active members*
3,666 visitors online*
Thread: Motor Tuning
    Motor Tuning
    Looking for some help with motor tuning.
    Specs:
    Nema 34 3.5 amp 1600oz/in motors
    DM860A drivers / 2000step/rev
    BL-MACH-V1.1 ST-V2 Breakout Board
    16mm ball screws 5mm pitch - 10160 steps/unit (inch)
    Mach3 Software - Version R3.043.062
    Windows 7 Pro OS
    When I open the motor tuning screen and tune the motors to 50ipm and velocity of 10 in/sec/sec. all the axis's move smooth and motors sound fine. After I save the settings and exit and move any axis the motors sound choppy and not at all smooth. I have tried adjusting everything ipm, velocity, kernel, nothing has helped. Any help or suggestions would be greatly appreciate. Thanks for your support.
    Re: Motor Tuning
    So I have solved my problem! Apparently my PC was not enough to run the Mach 3 software.
    Old PC!
    Dell Optiplex 3Ghz cpu
    1 G Ram
    Win7PRO
    New PC
    HP 3Ghz
    3 G Ram
    Win7PRO
    Now I have tuned my motors to 250ipm and it runs like a dream. Motors are smooth and quite.
    Jan 2018
    1516
    Re: Motor Tuning
    Computer needed more rams....... Baaaaaa!
    I'm using optiplex too, 4gb ram, 2gb pci-e gfx card, but using XP os instead. Win7 is too bloated.
    I have the same breakout board type. I'm suspecting you were you using the on-board graphics chip?.
    What CNC machine have you got?
    I've tried those 1600oz motors before on a PM25 size mill and litterally threw them in the bin. Inductance was terrible.
    Couldn't get above 1000mm/min (40ipm) without stalling or screaming (on 60V).
    I learned the hard way as a newbie
    I changed to some 566oz (on 60V) and the machine flies.
    Cam rapid at 3000mm+ (120ipm) and accel at well over 1000. I'm lmited by kernel. Going to upgrade to a UC300ETH.
    5mm screws, drivers at 3000/rev, motor 600, kernel at 35000.
    (I use mm)
  1. motor tuning
    By pecos in forum Spanish
    Last Post: 03-15-2013, 09:28 PM
  2. Help with motor tuning
    By precisionhone in forum Machines running Mach Software
    Last Post: 12-23-2011, 07:24 PM
  3. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  4. Motor Tuning
    By dwacker in forum DIY CNC Router Table Machines
    Last Post: 05-01-2007, 03:50 AM
