586,036 active members*
3,743 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > G code to cut inside groove
    Mar 2006
    51
    I am using BobCam to cut an inside grove in a steel 1/4 inch hole. My tool is a 1/4 in. shank and cutter with 3/16 shaft. The groove need be only .01 deep. The posted code starts the cutter -.0075 in X and 0 in Y. If BobCad cant stat the X and Y at zero it is a no go. I do not write G Code so correcting this is beyond me.
    Nov 2013
    4373
    Re: G code to cut inside groove
    I'm not at all familiar with Bobcam however most CAM programs offer a thread milling toolpath.
    In that circumstance the Gcode lowers the tool into the hole on center and then move outward radially to start the groove.
    In a thread the groove is a helical path, but as you want a straight groove then nominate the 'pitch' of your 'thread' to be zero.
    The CAM should handle how the get the tool in and out of the hole thereafter.
    Craig
    Mar 2006
    51
    Craig
    I didn't think of that. Of course. Thanks
    Tom
    Sep 2020
    14
    Seems like you need to set your lead in/lead out correctly. Also dropping into a 1/4 hole with a 1/4 cutter makes it more difficult to get a nice ramping in ramping out.
  1. macro code inside of a subroutine
    By brockmo in forum Fadal
    Last Post: 03-13-2009, 04:32 AM
  2. How do you cut square inside coners?
    By Astroguy in forum Benchtop Machines
    Last Post: 08-16-2007, 02:11 AM
  3. What kind of tools used to cut v groove pullys?
    By QSCNC in forum MetalWork Discussion
    Last Post: 12-23-2006, 03:24 PM
  4. Diameter of inside cut, too small
    By SVM in forum Uncategorised CAM Discussion
    Last Post: 06-19-2006, 03:17 PM
  5. Q: Best way to cut small oring groove?
    By Deviant in forum MetalWork Discussion
    Last Post: 06-23-2005, 07:38 PM
