586,103 active members*
3,697 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > Configuration of a bender in the Y1 axis parameter ADIRA PA02512
Results 1 to 2 of 2
    Jan 2018
    Dear good night,
    This is an ADIRA brand bender from Portugal, it is a CNC machine has an ADcontrol10 controller, a year ago the internal battery of the controller was spent, which caused some parameters to be deconfigured, especially the Y axis that makes the only piston not can go up since there is an input that should give 24VDC but due to the deconfiguration it does not give voltage, someone will know how to activate the parameters for this Y axis.
    Some photos are attached and the manual of the equipment I mention is also attached, as seen in this manual there is no description of errors, emergency codes and no configuration parameters, only some basic parameters at the user level, however someone with more experience could you support meClick image for larger version.
ID:	461477Click image for larger version.
ID:	461481Click image for larger version.
ID:	461479Click image for larger version.
    Este es el link del manual
    https://www.dropbox.com/s/3qh9z5c53o...rimax.pdf?dl=0
    Jan 2018
    Re: Configuration of a bender in the Y1 axis parameter ADIRA PA02512
    Se mueven algunos ejes pero falta la configuración
    Y1Type of motor 1
    Type of reference 0
    Encoder card 1 2
    Analog card 1 205
    no se si son valores correctos
