586,068 active members*
4,290 visitors online*
    Aug 2019
    13
    Ball screw nut circuits
    Need help with identifying and knowing the difference of ball screw nut, I being a Noob took the nut out of the ball screw, all bearing ball fell out, I managed to get them back in and it seems to work fine. I'm not too happy with it and ordered a new sfu1610-3 nut, I didn't realize that there are also sfu1610-2 nuts for sale.
    So my question is does it matter, will the 3 circuit nut work on a 2 circuit ball screw? Now I don't know if what I have is 2 or 3 circuit, how can I identify them?
    I want to know before trying it on, maybe return the sfu1610-3 and get a sfu1610-2.
    Any help would be great, thanks
    J.C
    Re: Ball screw nut circuits
    There shouldn't be any difference in the screw, provided both nuts are made to fit the same screw. 1610 is 1610, regardless of how many ball circuits there are.
    Aug 2019
    13
    Thanks for the quick reply, I tried searching everywhere and no one really talks about identifying ball screw nuts and circuits. I just didn't want to try using it and not being able to return a used item that didn't fit ????
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  3. Hurco ball screw nut
    By JWC in forum HURCO
    Last Post: 01-14-2018, 01:33 AM
  4. Need help: Identify ball screw/ ball nut
    By RickOmatic in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2012, 10:04 PM
  5. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2006, 04:53 AM
