586,801 active members*
6,236 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 1986 Mori Seki Mv Junior OT001 x & y over travel ( soft 1) Help!
    Apr 2021
    Hi so I recently got a 1986 Mori Seki Mv Junior with a Fanuc 10M control and upon getting it all wired up when I first went to ref/ home machine it will ref to Z axis but when you do X or Y you get a alarm OT001 x over travel ( soft 1) then same alarm if you do it in the Y. I tried the P and Can button at the same time that didn't work. I read on a forum that it said try doing the - and . buttons together that how ever did bring me to a page that I was able to hit #4setting then input and then the forum said hit 99 input to exit IPL mode. Then when you do that it asks you allow to pass axis? Y input I press then It says option 1? then wont let me type anything and keeps giving more option #'s looks like this
    option 1?
    option 2?
    option 3?
    option 4?
    Never got me anywhere so I hit reset and start over and repeat steps up too 99 rather then doing the 99 input there is a# 6 end IPL mode so I try doing that as well instead of 99 but same result getting the alarm codes.
    Re: 1986 Mori Seki Mv Junior OT001 x & y over travel ( soft 1) Help!
    How about opening the limits till home has been set? Parameter 5220 and 5221
    Nov 2007
    355
    You can get to the IPL screen but if you read the screen look for CHECK LIMITS AT POWER ON option -this is the one you need for it to go back and check for switchs -------Then end
  1. Mori seki junior
    By nissehult1 in forum Milling
    Last Post: 07-08-2019, 05:44 AM
  2. Mori Seki SL-1
    By MERCEDES in forum Mori Seiki lathes
    Last Post: 01-02-2015, 03:57 AM
  3. Replies: 6
    Last Post: 06-17-2013, 04:51 AM
  4. Mori Seki
    By br1 in forum Mori Seiki Mills
    Last Post: 09-06-2012, 05:39 PM
