586,047 active members*
3,658 visitors online*
    Dec 2007
    30
    slave axis stepper motor reverse when running
    I have a router with two stepper motors on the gantry, it was running ok but suddenly one of the stepper motor reverse it's direction, so they stalled because the gantry became unsquare, i turned it off and start again but still the same fail, does any body knows what could be happen with this problem?
    thanks in advance
    Noel
    Aug 2005
    205
    Re: slave axis stepper motor reverse when running
    This may be a control software issue. What software are you using to run your machine. In Mach4 there is the option to reverse the motor rotation in the motor setup.
  1. Issues with Slave axis while running in CNC mode Kstep
    By henradrie in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-30-2019, 08:43 PM
  2. Slave stepper motor
    By mirocha in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-29-2017, 04:52 PM
  3. Y Axis + Slave not running together when running G-Code
    By Fierra in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2017, 08:56 AM
  4. mach 3 slave motor(stepper) turns only one direction??
    By xkadet in forum Machines running Mach Software
    Last Post: 01-03-2013, 09:59 PM
  5. 4th Axis Slave Stepper or Not?
    By Dusty Mills in forum DIY CNC Router Table Machines
    Last Post: 03-26-2010, 02:46 AM
