586,089 active members*
3,867 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Looking for someone who can CNC 10mm acrylic sheets
Results 1 to 7 of 7
    I have been looking all over the internet for about 2 weeks now, plus contacting local machinists. I have been having a heck of a time getting anyone to call me back, or even interested in a one off.
    As the title say's, I am looking for someone who can cut 10mm acrylic sheets, max size is 554mm by 363mm, but I can chop that down to multiple parts for a max of 280x363 if I absolutely have too.
    *I have the CAD model almost finished, and I can export to whatever format you would need.
    *I need about 120 3.3mm holes drilled so that I can tap M4 threads in, unless you have a machine that can do this for me.
    *There are 16mm wide channels to be carved out
    *The toughest part is that there is a 2.2mm wide o-ring channel that is located only 1.5mm away from the main 16mm channels.
    I am located in Metro Detroit, but I have no problem contracting someone out of state.
    I do a lot of these kinds of projects so finding someone I can swap numbers with for future projects would be amazing.
    May 2003
    323
    Re: Looking for someone who can CNC 10mm acrylic sheets
    Dm me
    Jun 2010
    Please send drawing and .step file to me so I can quote. I am located in PA.
    Excellent! It is very much a relief to see not one but two responses!
    I have the whole model laid out, I just have to extrude all the recesses and then I'll export to a few diff formats and post a link here.
    I wont get home from work tonight until 2am eastern, I'll upload then and will check back tomorrow.
    Ty so much for the replies
    Jan 2011
    I would also be interested in the model/drawing for a quote. I'm located in the Grand Rapids area.
    I now have a dxf file, and I have included a png file with some basic dimensions.
    As far as the material, it does not have to be super fancy. I found a single sheet that will fit both parts on amazon for 70 dollars that I can order and have delivered directly to anywhere.
    https://drive.google.com/file/d/15QI...ew?usp=sharing
    Jun 2010
    Can you provide a .step file?
  1. Need a company to machine acrylic sheets
    By dante1 in forum Canadian Club House
    Last Post: 02-08-2015, 06:08 PM
  2. Chinese Acrylic Sheets Supplier
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-17-2013, 09:36 AM
  3. Replies: 0
    Last Post: 02-21-2013, 07:53 AM
  4. Replies: 0
    Last Post: 02-18-2013, 10:34 AM
  5. 10mm acrylic cant cut
    By cornelis1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-03-2012, 04:33 PM
