586,032 active members*
2,931 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > No backlash adjustment screw on feed nut bracket(yoke)
    Jan 2021
    6
    I have a supermax ycm1 1/2 va and somehow the feed needs (2 nut design) came out of the bracket so I removed the table and lead screw to feed the assembly back into it but noticed there were no adjustment screws at all not even a tapped hole for an adjustment screw to go into. The bracket does however have a boss where it looks like the screw would normally go. Is there some other mean of adjusting the backlash on these machines?
    Feb 2008
    69
    Re: No backlash adjustment screw on feed nut bracket(yoke)
    Do you have a picture?
    Sent from my 5007U using Tapatalk
    Feb 2008
    69
    You could make a shim stock washer under I of them, then reinstall it.
    It will take a bit of fiddling to find the right thicknesses, and will depend if you screw is worn in the centre.
    Or just add the slots in the nut yourself, only 1 needs to be done.
    If you don't have a rotary table, the slots could be marked out and filed out, as it's only Bronze.
    Jan 2021
    6
    Quote Originally Posted by Davo J View Post
    Hope the pics showed up.
    If they did well that’s the exact bracket I believe I have. I don’t think it’s the original.
    I’m leaning towards slapping the yoke on a drill press. Scary thought however.
    Side note: how do the nuts in the supplied pic work as far as adjustment goes?
    Jan 2021
    6
    Davi J attached pics of the bracket I have in the reply above this one. Have a gander. Of course with out those actual feed nuts. I have split nuts.
  1. Y axis backlash adjustment nut
    By pritch1986 in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2014, 01:07 PM
  2. Nut Housing/Nut Bracket - Commercial or Custom?
    By Bear5k in forum Linear and Rotary Motion
    Last Post: 06-17-2011, 06:03 PM
  3. Bridgeport Feed Nut Bracket Dimensions Needed
    By bbutcher85710 in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2011, 01:29 PM
  4. Does one need an anti backlash nut with a ball screw?
    By JimmyL in forum Linear and Rotary Motion
    Last Post: 06-12-2009, 08:04 AM
  5. acme lead screw and phosphor bronze anti-backlash nut any advice?
    By rhino in forum Linear and Rotary Motion
    Last Post: 05-20-2006, 09:29 PM
