586,117 active members*
3,606 visitors online*
Thread: TNG Network.
Results 1 to 10 of 10
    Jun 2017
    119
    TNG Network.
    Not able to connect to TNG via network.
    Worked perfect with USB controller and network.
    I enable network in settings but nothing is showing.
    Aug 2020
    131
    Re: TNG Network.
    you need to have the Ethernet adapter that you are using configured with the correct IP Range. You can check the IP of the Pkanet Board in the "Set Parameters" for the controller (in the Machine Menue)
    Choose a IP in the same range and enter the IP of the Adapter that you are using in the Settings Menu as "Adapter IP"
    Closing and reopening of the Settings Menu might be required to make the board visible after setting the Adapter IP.
    Jun 2017
    119
    Re: TNG Network.
    Quote Originally Posted by ScorpionTDL View Post
    Ethernet Adapter? Under settings - Connection?
    The IP of the adapter when connected with usb = 192.168.10.147
    I have set the IP address under Connection to the same thing, but it's not working.
    Tried with DHCP on and off.
    It worked flawlessly with the old software...
    Also when I'm connected with USB the machine laggs like crazy. When I use arrows for moving the axes they stutter and are really laggy in their movement.
    Mar 2017
    1312
    Re: TNG Network.
    Did you configure controller IP?
    Jun 2017
    119
    Quote Originally Posted by PlanetCNC View Post
    Where? I've been to the screen where you can enable and fisable DHCP etc.
    Aug 2020
    131
    Re: TNG Network.
    I covered the Network setup in one of my Videos, its in German but maybe with the autogenerated English subtitles its enough to give you a rough understanding how to do the configuration:
    https://youtu.be/BT7YZNgKYO0?t=166
    I'm talking about the connection starting at 2:40
    Jun 2017
    119
    So with TNG you have to connect the ethernet directly to your pc??
    With the usbcontroller I have a switch(router) inbetween the pc and the controller board. Have had no issues with this at all.
    Are you telling me I now need to buy a crossover ethernet cable and another network adapter for my pc to be able to use network with TNG?
    Aug 2020
    131
    Re: TNG Network.
    you still can connect it to your switch. As I have multiple network interfaces on my PC I simply used a dedicated adapter.
    However you still need to ensure that the ethernet adapter on your PC has a IP Address in the Same Range as the Planet Board and you need to enter that IP Address into the Settings Menu of TNG.
    edit: for a direct connection you might not need a crossover cable. If your PC is running a Gigabit adapter it should have Auto-MDIX which autodetects the need for a crossover cable and automatically adapts itself to handle this.
    Jun 2017
    119
    Re: TNG Network.
    Randomly decided to work now. So this issue is fixed for now. Thanks.
    On another note your movies are only subtitled to German. I were not able to pick english, might this be a setting from your control panel on youtube?
    Aug 2020
    131
    Re: TNG Network.
    I'm able to switch to auto translated English on the subtitle.
  1. In software TNG
    By suli25an in forum PlanetCNC
    Last Post: 01-12-2018, 11:14 AM
  2. TNG and SD card.
    By t991731 in forum PlanetCNC
    Last Post: 12-21-2017, 11:41 PM
  3. Setup TNG
    By laluna in forum PlanetCNC
    Last Post: 11-27-2017, 10:32 PM
  4. Replies: 4
    Last Post: 11-09-2015, 02:37 PM
