HI
I haven’t used my new CNC router since last year
Im trying to learn what I learned before but I need help
Last year I got cutting
Im using MACH3 and VCARVE
Im trying to cut a basic circle as im a bit rusty lol
Okay when I load the Gcode and Use the paper method to lower the Z axis
I then go on too MACH3 and ZERO All axis then I click cycle start! I presumed it would cut the hole straight away but the issue I have is
The Z Axis lifts way to high around 6cm then hits my Hard limit and stops MACH3 and I have to reset it after manually lowering the Z Axis
Do you know how to stop the Z Axis lifting so high???? Is it did in MACH3 Or is it my gcode via VCARVE?
Thanks, I always come back and update!
Adam
