586,121 active members*
3,139 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 400XLM Automatic Q setter operation
Results 1 to 6 of 6
    Mar 2014
    9
    Hi.
    I was wondering if someone could give me tips/pointers on how to automate the use of the Q setter.
    My goal is to be able to change inserts or mount established tools with their appropriate offsets, and using established offsets get an automated and accurate measurement.
    I have one colleague who spends the first 15 mins of his shift touching off everything in the revolver. I want to either use established cycles or use a macro to automate that.
    There are under "Mescycle" some measuring cycles in EZ guide. But I had no luck getting that to work.
    Thanks in advance.
    Jul 2005
    380
    Re: Puma 400XLM Automatic Q setter operation
    The machine will not index the turret or rapid traverse, if the tool setter is activated and in the down position.
    Does your Puma have the motorized tool setter?
    Mar 2014
    9
    Yes, it is motorized and I can move it up or down with an M code.
    Jul 2005
    380
    OK, so there should be a macro to auto set the tools.
    I'm wondering if it isn't already hiding in the CNC's memory someplace.
    Fanuc 32? 31? i?
    Look in the directories, there may be one.
    Mar 2014
    9
    I have looked and looked for registered macros and made all possible hidden programs visible. And no result yet. There are the cycles I mentioned, but they are a mystery to me how they'd work.
    It's a 21iTB controller. I should have mentioned that earlier.
    Jul 2005
    380
    Ok, if there are cycles in there, there has to be documentation. Check your Doosan (not Fanuc) operator's manual.
  1. Puma 400XLM M31 not working.
    By Electronaughty in forum Daewoo/Doosan
    Last Post: 04-05-2021, 11:34 AM
  2. daewoo puma 200c tool setter
    By spirowski in forum Daewoo/Doosan
    Last Post: 12-29-2018, 04:03 AM
  3. Q SETTER ALARM , PUMA 240
    By DANIEL HALL in forum Daewoo/Doosan
    Last Post: 07-15-2016, 11:04 PM
  4. Puma 8HC tool setter useage
    By serickson in forum Daewoo/Doosan
    Last Post: 01-28-2016, 08:07 PM
  5. automatic tool length setter
    By Scottyb in forum Mori Seiki Mills
    Last Post: 01-25-2011, 05:15 PM
