586,035 active members*
3,642 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > How to replace servo drive in HITACHI HG400III
Results 1 to 8 of 8
    Hi!
    I have HITACHI HG400III, 1999, Seicos 16.
    I replaced XZ driver A06B-6096-H208 to new.
    It is 2 axis driver (L-M)
    Try to switch on the machine. Till "STANDBY" button all is OK.
    But after press this button all drivers show "5" in LED indicator.
    I checked axis table in working HITACHI HG400 and compare it with my machine under repair.
    The difference is in photo.
    Looks like SEICOS did not initialize driver and X and Z axis try to use A1-L driver together. In working HITACHI X use A1-L but Z use A1-M driver.
    Please help
    Aug 2011
    15
    Re: How to replace servo drive in HITACHI HG400III
    Hi
    Problem always arises with 6096 h208 drive unit, the software version in the drive changed, so you have to have very similar serial no on the drive for it to operate correctly
    Hi!Can I substitute new control board in driver to my old board? But power part with IGBT will be new, but control board with software old?
    Aug 2011
    15
    Never done that, dont know what changed internally in the drive, so cannot advise
    Hi! I dismount drive and found many problems:
    1. Drive A06B-6096-H208 is 2 axis drive. Control board has to be A20B2100-0253. It is 2 axis control board. In my case it is A20B-2100-0540. It is 1 axis board. So my CNC can not find second axis. It is the promlem. Moreover: The power board has to be A16B-2202-0774. This is 2 axis power board 80A/80A current. In my case it is A16B-2202-0743 power board 80A/40A current. I can not use this board in my machine. In fact: China company sent me the drive named A06B-6096-H122 and not A06B-6096-H208. The drive is not new. It shown in photo - damaged FAN and damaged heat radiator. The company name in Chian - Dongguan Tommy Cnc Machine Tool Fittings Co., Ltd.
    NEVER BELIVE THIS COMPANY.
    Problem was solved.
    I need to replace chip in board (see attachment). This chip (X24C04). This is PLC with interconnection protocol.
    I extracted chip from new board and replace new chip to old chip.
    After that all became OK.
    Quote Originally Posted by seikiman View Post
    Hi
    It was the same you wrote.
    Apr 2006
    111
    Quote Originally Posted by =aike= View Post
    Problem was solved.
    I think that it have no error but it is no good.
  1. HITACHI HG400III arm broken help!
    By =aike= in forum Mori Seiki Mills
    Last Post: 07-02-2023, 07:25 AM
  2. HITACHI-SEIKI HG400III SIGMA 10 BACKUP
    By =aike= in forum Mori Seiki lathes
    Last Post: 03-12-2020, 09:12 AM
  3. Hitachi Seiki HG400III 12 pallet pool
    By rick kroeze in forum Hitachi Seikis
    Last Post: 02-16-2016, 11:06 PM
  4. HITACHI HG400III TOOL DROP error
    Last Post: 05-23-2011, 07:56 AM
