586,058 active members*
4,716 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seicos VM4III 18iM - Rigid Tapping Parameter Setup
    I have a machine of Hitachi Seicos VM4III using Fanuc 18iM + Seicos OS.
    Now, it can not using Rigid Tapping.
    When I checked parameter of rigid tapping, i saw it have more parameters related rigid tapping.
    But I don't know how to setup them.
    Pls see attachment and help me if you can.
    Aug 2011
    15
    Re: Hitachi Seicos VM4III 18iM - Rigid Tapping Parameter Setup
    Parameter setup looks very much like most Hitachi Seiki's
    Hitachi do not use M code for tapping
    Call line is G84.1 Z-14. R 3. (example) and ends with G80 as other drilling cycles
    Thank you so much. I will try this way.
  1. I goofed / rigid tapping parameter
    By teamjnz in forum Haas Mills
    Last Post: 10-16-2015, 06:42 PM
  2. Replies: 1
    Last Post: 07-06-2014, 04:44 AM
  3. Rigid Tapping on Seicos control
    By talyrond in forum Mori Seiki Mills
    Last Post: 07-20-2011, 01:19 PM
  4. rigid tapping parameter
    By timmydabull in forum Haas Mills
    Last Post: 06-26-2009, 01:48 AM
  5. rigid tapping on Hitachi-Seiki HT-23J Lathe
    By jbird68 in forum G-Code Programing
    Last Post: 09-21-2007, 02:02 PM
