586,094 active members*
3,709 visitors online*
Results 1 to 8 of 8
    Harmonic drive knocking noise
    https://youtu.be/XhlZheT1fu0
    Hello, i recently got a 4th Axis harmonic drive for my diy mill. It works totaly fine but makes some strange knocking noise when spinning in one direction (clock wise @12sec in the video).
    Is this something to worry about?
    Dec 2013
    5717
    Re: Harmonic drive knocking noise
    It sounds more electronic than mechanical. Like the stepper motor is skipping a beat or something. I would remove the stepper from the unit and see if the same thing occurs. Then rotate the harmonic drive by hand and maybe you can feel something. Maybe put a shaft in an electric drill to rotate the harmonic drive to check for a mechanical problem.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2006
    42
    If you've had the drive apart, check to be sure the flex spline isn't off-center. If the spline is installed correctly where it only contacts the circular spline 180* apart. If the flex spline is even 1 spline off, you will get contact between non-engaged spline tips on one half of the circumference, so you'll get knocking/tapping in one direction as the splines snap over each other.
    Today i tried to spin my drive by hand couldn't hear any knocking tough. Also wen spun by the stepper the knocking seems to just went away. All it makes now is a gentle grinding noise, its a bit uneven tough. Does not sound too bad, but as i have no previous experience with harmonic drives dunno if thats normal?
    Mar 2006
    42
    Check through this.
    I suspect your problem is covered on page 35 out of 57.
    https://www.harmonicdrive.net/_hd/co..._Component.pdf
    Jun 2010
    4256
    There are two page 35s in that PDF. One is an index; the other is the back page.
    Help?
    Cheers
    Roger
    Dec 2005
    596
    Quote Originally Posted by RCaffin View Post
    Help?
    Cheers
    Roger
    Roger,
    You've either got a reader that's whacked or you downloaded a corrupted copy of the pdf. Page 35 in the document I downloaded from the link above covers torque limits.
    Mark
    Jun 2010
    4256
    Ah, I see. I went to p 35 according to the page numbers in the corners, as marked by HD.
    You were referring to Torque Limits on the 35th page of the doc. The page number for that is 13 (see number in corner).
    Cheers
    Roger
  1. how do these compare to a harmonic drive?
    By acannell in forum Linear and Rotary Motion
    Last Post: 06-15-2014, 03:52 PM
  2. Harmonic drive help
    By irishjam in forum DIY CNC Router Table Machines
    Last Post: 01-01-2012, 10:46 PM
  3. Screeching Steppers Harmonic/Noise Reduction
    By catabolic in forum Stepper Motors / Drives
    Last Post: 07-13-2011, 01:51 AM
  4. Is this a harmonic drive?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 02-14-2011, 08:06 PM
  5. Harmonic Drive
    By juzwuz in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2005, 08:28 AM
